Rebuilding my LS2 with Maggie 112 questions
Spun a crank bearing, scored two piston walls. So now rebuilding, 5 thousands over and all new pistions, etc. While I am here I will be putting in a new blower cam, had LS6 in there. Since I will be losing some boost with the new cam I plan on changing out pulleys. Going with overdriving the rear, underdriving the crank pulley and then testing the front. Any thoughts here? Trying to get 9-10lbs boost out of it.
Also my fuel system,
I currently run a Walbro 255 but looking to add the Racetronix Hotwire Kit or?
I have the bosch 280150558 injectors which are 42lbs and believe they came with the maggie. Should I upgrade these to 60lb ones or???
I am looking for 600-650 out of it.
supersub on here, (Ray) can probably tell you what pulley to use. Bob
