Eboost2 guys and particularly aps guys where did you mount the solenoids..pics ??
Old 03-02-2010, 11:20 AM
MY99TAWS6's Avatar
Default Eboost2 guys and particularly aps guys where did you mount the solenoids..pics ??
Going to be installing my two eboost solenoids soon and wondering where you guys put them,especially aps guys. I have been running my eboost just as guage not controller so time to start dialing up the boost shortly.
Also did you use connection method one or two from the instructions..
I don't want to change out gate springs if don't have to since like the added range of having a lower spring but do need/want to be able to likely get 20psi max out of the setup occasionally. Anyone able to get 20psi with the 7.5psi spring depending on which hookup is used?
Old 06-26-2010, 03:23 PM
MUSTANGBRKR02's Avatar
Anyone?
Old 06-26-2010, 05:37 PM
tomz28's Avatar
ill get you some pics AL but my labtop went to **** so give me some time
Old 06-26-2010, 05:44 PM
barnat's Avatar
I didnt think you could (get past) doubleing spring pressure wheather using a manual or electrical boost controler (E Booste )If your wanting to see a max of 20psi, i think 10psi (Large Yellow) springs are what your going to need? I think thats why Al is getting a set of 10lbers for his ride
Im ditching my 10psi springs for a set of 12lbers for the street myself and will use my manual controler for a 15psi jump for the track and call it a day
Old 06-27-2010, 07:09 PM
Well i have mine mounted where the sway bar mount went. I'll post up some pics in a bit.
Old 06-27-2010, 11:54 PM
MY99TAWS6's Avatar
It might be possible to push past double spring with electronic like eboost or that ams 500 or whatever with co2?
Tom has eboost so guess can see what springs he runs and how much he gets.
Old 06-28-2010, 08:02 AM
LS1Tech Sponsor
Superman09's Avatar
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 06-28-2010, 01:23 PM
DanDan's Avatar
Also interested in seing where other owners are mounting their solenoids. I want to see 18 - 20 out of my kit with the eboostII.
Old 06-28-2010, 01:29 PM
MY99TAWS6's Avatar
Originally Posted by Superman09
Superman are you running only one solenoid?
Old 06-28-2010, 01:41 PM
cracker's Avatar
KWIKSS is running one solenoid making 1000 rwhp.
I have personally seen many TT 03+ Cobras running a single solenoid at 25+ psi.
Old 06-28-2010, 07:02 PM
Are the threads on the solenoid 1/8 NPT? I have to do some switching of nipples on this kit that i got.
Thanks
Old 06-28-2010, 08:05 PM
98Camarod's Avatar
Here is where mine is:
Old 06-29-2010, 04:48 PM
Thanks for the pics guys. I ended up mounting mine here.
Old 06-29-2010, 11:02 PM
LS1Tech Sponsor
Superman09's Avatar
yea, only one is needed
__________________
Old 06-30-2010, 12:22 AM
MosesMcgregor's Avatar
Behind the battery
https://ls1tech.com/forums/11592025-post147.html
Quick Reply: Eboost2 guys and particularly aps guys where did you mount the solenoids..pics ??
