3 bar MAP - install Qs
Old Mar 17, 2010 | 07:08 PM
Eagle02's Avatar
Default 3 bar MAP - install Qs
I bought a 3bar MAP, but its not the same size as the stocker. It also came with a DIY harness adapter... it looks like this:
So my next questions are:
  1. how do I install the MAP?
  2. does anyone out there have the info to wire up the adapter correctly?
Thanks for any help!
Old Mar 17, 2010 | 07:29 PM
HUNTER02SS's Avatar
Well, I guess I will be the first to tell you.
That is a MAP Sensor you are asking about. Not a MAF sensor.
Old Mar 17, 2010 | 07:38 PM
mr_biscuitz's Avatar
i too would also like to know, I found a couple threads that say some stuff but its nothing def.
Old Mar 17, 2010 | 08:22 PM
mike13's Avatar
http://www.lsxtune.com/shop/product_...roducts_id/781
this is what I did and mounted the sensor in the engine compartment and ran I vaccum line to it.
Old Mar 17, 2010 | 10:29 PM
yeah that would work great but when I had the 2 bar a shop wired it in so i dont have that fancy little factory connector any more.
Old Mar 17, 2010 | 10:47 PM
mike13's Avatar
I would think the wiring would be the same in relationship to the connector.
Old Mar 17, 2010 | 11:00 PM
wires are different colors
Old Mar 17, 2010 | 11:06 PM
ZTwentyAteU's Avatar
isnt the stock one ground, 5v ref, and power? you would think it would be the same on this one. i'm guessing black is gnd, blue is 5v ref, and the red is power. look on your stock map, it may be on it what the wires are. I know one of the map sensors shows you what the wires are on it
Old Mar 17, 2010 | 11:28 PM
Eagle02's Avatar
So mount the MAP somewhere and run a vac line to it. I looked over the stock MAP tonight and I didn't see any markings for what is what... might have to find a wiring diagram for that circuit?
I suppose I could just leave the stock MAP in the rear of the LS6 intake then?
What is the best source of vac for the MAP?
Old Mar 18, 2010 | 12:01 AM
after a quick search I came up with this
A = orange with black (sensor ground)
B = light green (sensor signal)
C = gray (sensor 5V reference)
you could tee the line for the evap junk on the drivers side front of the intake and use that or tee the other side of the intake that has a port there too
Old Mar 18, 2010 | 05:54 AM
blk00ss's Avatar
Or run a 1/4" NPT tap in the map sensor hole. Then screw a barbed fitting in the hole, run a line from there to sensor.
Old Mar 18, 2010 | 08:06 AM
Eagle02's Avatar
Awesome, thanks man!
Interesting concept, but there isn't much meat to tap back there. I think I'll just use one of the vac sources on the front of the intake.
Old Mar 18, 2010 | 08:13 AM
mike13's Avatar
When you get your car tuned let us know if there where any issues with the 3 bar tune process.
Old Mar 18, 2010 | 08:19 AM
A- Ground
B- Signal
C- +5 volt source
I knew that I didnt know what the stock wires were
Old Mar 18, 2010 | 08:35 AM
Eagle02's Avatar
I will update on the tuning once I get the car rolling. I think I'm going to go back to a stock tune, then convert to 3bar OS, make a couple tweaks to the base tune and then start with the SD tuning.
