Finally Got Dyno #'s With Maxed Out D1SC
Old 03-19-2010, 12:10 PM
AFASTYZFR1's Avatar
Originally Posted by blk00ss
Man I hope my 404 can make those kind of numbers lol! Was that through the exhaust, or through a cutout?
Yes, that was through exhaust......I want to get a cut-out at some point
Old 03-19-2010, 02:18 PM
blue00ZZleeper's Avatar
Pick up the truck inlet from bob and see what she does. A couple of people have done that and picked up a little bit. I bet it'll put you over 700 with the hat and filter. She sounds like shes a handfull on the street though lol.
Old 03-19-2010, 03:02 PM
BLNLS1/RX7's Avatar
Congradulations-very nice build.
Old 03-19-2010, 04:06 PM
MIGHTYMOUSE's Avatar
nice job guys!
Old 03-19-2010, 04:29 PM
LS1RedZ's Avatar
I bet you will pick up AT LEAST another 40rwhp with a cutout. Im running 1 3/4 pacesetters w/ ORY into a spiral flow to a center mount also. I picked up 70rwhp opening up the cutout with the stock intake hat on @ 15psi.
Old 03-19-2010, 05:00 PM
AFASTYZFR1's Avatar
Originally Posted by MIGHTYMOUSE
nice job guys!
Thanks David
I will make it out to one of the meets as soon as I am free.
Old 03-19-2010, 05:19 PM
mean94lt1's Avatar
great numbers man that car is bad *** looking i love the color
Old 03-19-2010, 06:27 PM
AFASTYZFR1's Avatar
Just made a screen for the track tom
Old 03-19-2010, 06:30 PM
Sweet man!!...have pics of the inside of it? I need to make one as well.
Old 03-19-2010, 07:09 PM
T/A KID's Avatar
How did you make it? Where did you get the supplies, I'm pretty handle, so I can probably make something similiar with some info.
Thanks, awesome build
Old 03-19-2010, 10:22 PM
jomomma's Avatar
so i guess you wont be needing the k&n filter after all! that screen you made looks very similar to the one i fabbed up. im sure you will ok with that setup. hopefully you guys will get some good vids of your runs! im pretty sure your going to have a short day at the track, especially after your first run, unless you baby it!
Old 03-19-2010, 10:44 PM
  #32
DaytonaFIC6's Avatar
very nice numbers. I really like the look of the SS's with center exit exhaust.
Old 03-20-2010, 02:05 AM
  #33
AFASTYZFR1's Avatar
Haha, yea I am going to baby it unless I get a decent launch
As far as the screen goes, I will get more pics of it for you guys tomorrow and tell you how I made it.
Old 03-20-2010, 02:38 AM
  #34
01Z28Camaro's Avatar
Screen looks like a huge restriction to me. An for those wondering you can pick up screen material by the foot and cut to fit, use a simple clamp to hold it together.
Old 03-20-2010, 08:09 AM
  #35
AFASTYZFR1's Avatar
Screen is held between two pieces of a coupler and glued together. Got 4" coubler at napa and screen at lowes
Old 03-20-2010, 09:09 AM
  #36
30th t/a's Avatar
That is one sweet ride and setup! wow!
What CR are you running?
Old 03-20-2010, 05:51 PM
  #37
AFASTYZFR1's Avatar
Made it to the track and it was perfect weather. Unfortunately my textralia single disk was not up to the challenge. It got roasted all the way down the track But now that it has cooled off it holds the low boost tune on the street just fine......so until it doesn't work on the street anymore or I decide to get a 4l80 I guess I can't get a decent run in.
Screen didn't work out so well, but I got lucky and nothing got sucked in. The piece that is missing fell off while my tuner was holding it I will have to work on a new screen that has really strong mesh
Old 03-20-2010, 08:40 PM
  #38
conan's Avatar
Sorry to hear about the bad day ( clutch & screen ) What did it end up running with the slipping clutch? Don't Know if this would help you but I gained 2# of boost going to a bigger filter and adding this to the bypass return hole.
http://mycarpics.shutterfly.com/277
http://mycarpics.shutterfly.com/278
Old 03-21-2010, 08:33 AM
  #39
383camaroz28's Avatar
ill buy ur head unit !
Old 03-21-2010, 09:21 AM
  #40
AFASTYZFR1's Avatar
I already have the large filter and small filter on bypass port
What does it matter what it ran with a slipping clutch Clutch slipping BAD as in motor on shift light and me barely going anywhere....I will try and post the video cause it looks good until the top of first and then I got nothing....and puffs of clutch smoke came out when I shifted
But it ran a 11.5 and I gave up once I got into 4th about 3/4 way down track
Quick Reply: Finally Got Dyno #'s With Maxed Out D1SC
