Still having issues after Procharger install
The lean condition was fixed by bumping up the Injector Offset table. Ideally, this needs to match the injectors as close as possible. A small error in this table can cause big errors in low pulse width fueling. I run 60s as well and these numbers should get you started.
12V 0.790
13V 0.638
14V 0.502
Next is the O2 switchpoint settings. Tuning this table will bring the rich idle and cruise back up to where its supposed to be ~ 14.7.
Then get a wideband and do some logging. Log AFR and MAF freq. Recalibrate the MAF and VE tables. This will help so much with your part throttle driving. Blower ducting upsets a MAF and the factory calibration just won't work any longer. Hell, just a different intake can throw off a MAF calibration. Good Luck.
12V 0.790
13V 0.638
14V 0.502
Thanks man. I wish I could look at these numbers, but I don't have HPT or any tuning software yet...just going off a base tune I got from Frost. Don't know if you can view my run file posted by ak95ta on the second page of this thread or not, but I'd be curious to hear your thoughts.
I'm just frustrated and talking out of my ***, but wondering if I shouldn't just put this thing back the way it was...
