Still having issues after Procharger install
Do you have a fuel pressure gauge? Is that reading like it should?
Fuel pressure reads 62 on the Autometer electric gauge.
Is there any way to test the injectors, or have them tested? The problem I foresee is putting the stock tune and stock injectors back on there and it running fine...then not knowing if the tune was the problem, or if it was the injectors. Obviously I'd lean toward the injectors, since Steve has gone over this tune numberous times, but I surely hate to spend another $275-$300 on injectors and have the same problems.
