Still having issues after Procharger install
When can I grab those bad boys from you? No rush or anything...just whenever you have time.
The Fed Ex guy brought my big box of goodies today also. I have 4 more wiring harnesses that I don't know what to do with. Time to read more directions.
I've been off sick for the last couple days. Had nothing else to do. I even pulled and rechecked my injectors today to make sure they're seated. No luck there either.
http://www.summitracing.com/parts/SME-DVD-1/
Really?? So the car runs fine OL, in CL, some o2 error causes problem and it's in the TUNE? Idle air trims add up to -7g/sec (shown lb/hr in the log) on his STOCK ENGINE WITH STOCK IDLE AIRFLOW TABLES. He sends me an HPTuners log that was made with a misfire counting cfg that SHOWS MISFIRES in more than one cylinder but you think it's the tune? Weren't you the one that made this log that was sent to me? Did you look at the log at all before you jumped in and said "LOL, yep, in your tune like we said"?
There is mention of exhaust leaks in this thread and then the mention that the car does NOT have issues with the O2s unplugged. You see high 12s at idle and just above in OL because the OEM OL fuel table ASKS for the car to be rich like that. You don't think it's odd that it's fine in OL?
I have triple checked his file. This is not some exotic build, it's a stock engine car with 60's, a pump, headers, and a SC.
Here is screen shot from the log that I was sent that shows the misfires and shows the - air (not fuel) trimming...AFR error is not working because wideband is not logged, that's why it shows 12%:
No one once said you were a bad tuner Frost, if you are saying you are infallible then show me your brochure and Ill start attending your church because I think I found a new god.
