Still having issues after Procharger install
The O2s I bought are the longer Corvette ones that work with headers...no need for extensions. So its not an O2 issue.
I have no idea what to look for next. It idles fine with the O2s unhooked...wideband shows 12.6. Just can't put it under load. Hook the O2s back up, and the idle goes way lean, and it surges if you give it any gas...also way lean. Injectors? I'm considering sending the computer back to Frost and having the stock tune put back on, and then swapping the stock injectors back on and seeing what happens.
I was in your shoes last year on the dyno with my friend's camaro. Needless to say we gave up at about 2 in the morning, never got it tuned (we started around 1pm) and ended up getting a Big Stuff 3. That is soooo easy to tune.
. It's about getting your car to run right.
