Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Camaro and Firebird: Guide for Budget Engine Swap
Important information to help you understand your Camaro or Firebird
lm7,lq4 or lq9?
an LM7 will hold more boost with truck heads (317), the LQ4 is a low compression engine with a slight dish in the pistons, and the LQ9 is the same as an LQ4 just with flat top pistons.
depending on what your plans are and your budget is the factor.
with an LQ4/9 you can make a 370 or a 408 and boost it up. on an LM7 with the 317 heads you can push up to 18psi from what I've heard.
on a low budget I would say do the LM7. you can pick one up at a junk yard for a few hundred usually, then re ring it and new bearings, you can cam it and throw some stock 317 heads and run 15psi all the time with no problems.
Agree. 5.3's are common in the bone yards. Found one with around 30K on the clock for under $450. No need to do anything to it other than run it. I don't know how long it would live at 15 psi, but I'd bet it would live a long time at 8 to 10psi. My son has been running it for quite a few thousand miles at 8psi. I expect something else to break before the motor.
I've seen 8xxHP/8xxTQ out of a stock to bottom end 5.3 with twin GT30 i believe
here : http://www.norcal-ls1.com/forum/showthread.php?t=61142
5.3, 317's, arp headbolts, 02+ ls6 cam, dual valvesprings, MPT70/.96ar turbo, homebuilt frontmount with intercooler..... stock shortblock!!!
pushing 17psi DAILY, has prolly 600 good long pulls on it... runing 91 ocatne pump gas NO METH...
It puts down 634rwhp! Could do more but wanted it to last a while.... its made it longer than i ever thought it would! I have seen them put down over 800hp like stated above but dont last long...
This is a very proven setup! and extremely budget.... I am considering selling my motor/turbo setup and moving on up to a twin turbo 408 really soon....
i expect to blow my factory 141k long block very soon after i install the turbo, the following setup will be lm7 with arp rod bolts and head studs with a cam and headwork, ls6 intake etc. ive seen guys take them to 18psi for a single pull.
Ya the ls6 cam dies out at 5700rpm and thats all it will do.... but atleast it keeps the rpms down so i dont have to turn the thing sky high to make power on the stock bottom end!
will ls1 headers bolt to a 5.3? i wanna do the motor swap but the car is my dd so i wanna do it as quick and inexpensive as possible than i will get all the pieces for the turbo set up than do all of that at once.
