STS to Trick swap
Old Apr 25, 2010 | 10:54 PM
2ktransam's Avatar
Default STS to Trick swap
So I finished the swap and headed to the dyno on Friday. I still need to fix a few issues and work on the tune a little but I got some comparison numbers. I have attached the dyno sheets for comparison. The STS kept up better than I thought but look at the power under the curve with the faster spool time.
Low boost off the wastegate spring
STS - 7.75psi
Trick - 6.75psi
STS - 405/419
Trick - 400/430
More boost
STS - 12psi
Trick - 12psi
STS - 544/571
Trick - 559/622
Final pull
STS - couldn't load past 12psi on the dyno
Trick - 14.5psi spike and settles to 13.5psi
Trick - 610/660
I need to figure out why the boost is dropping 1-1.5psi after it spikes but I'm pretty happy so far. The uncorrected numbers today were 627/677 so it feels very good on the street. Also the last pull was run #104 on this stock Lq4 and it keeps on taking a beating. I might switch to 3bar and see what it will take.
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 26, 2010 | 05:46 AM
pber13's Avatar
this is certainly a great comparison! I'm guessing the Trick kit isn't a rearmount?
Old Apr 26, 2010 | 06:04 PM
Zombie's Avatar
WTF is a trick?
Old Apr 26, 2010 | 06:21 PM
2ktransam's Avatar
Trick is a sponsor on the truck site that makes front mount turbo kits for gm trucks.
Old Apr 26, 2010 | 06:59 PM
dschmittie1's Avatar
how about we post up some pics
Old Apr 26, 2010 | 07:13 PM
2ktransam's Avatar
I'll try and get some tomorrow and post them up. It's a really simple setup that uses the stock drivers side manifold and a crossover under the engine that connects to a log manifold.
Old Apr 26, 2010 | 07:17 PM
mike13's Avatar
This with the stock LQ9? What are the specs on the turbo? Thanks for the information
Old Apr 26, 2010 | 08:07 PM
OreoLt1's Avatar
http://www.trickperformanceproducts....cts_turbos.htm
Doesnt look to bad but in the low mount kit I'm not to sure about the BOV ON the IC? Maybe just my preference...
Old Apr 26, 2010 | 08:33 PM
2ktransam's Avatar
Engine is a stock junk yard LQ4 with a Z06 cam and good valve springs. Turbo is a Turbonetics T76 BB with .96 exhaust housing.
Old Apr 26, 2010 | 08:39 PM
1fast bird's Avatar
I'll trade ya my car for it!
Old Apr 26, 2010 | 08:41 PM
2ktransam's Avatar
I actually bought my kit used from the white truck that ran 10's on their site.
It is the high mount kit.
http://www.trickperformanceproducts...._customers.htm
Old Apr 26, 2010 | 08:52 PM
mike13's Avatar
Cool, so it's the T76 with the large compressor housing and not the smaller TC series?
Old Apr 26, 2010 | 09:00 PM
2ktransam's Avatar
Yes, it has the big t series compressor housing. I thought I had a TC until I saw one the other day and realized how much smaller they are. I could make a lot more power with this turbo but this is my daily driver so I'm trying to keep it in one piece. LOL
Old Apr 26, 2010 | 09:09 PM
1fast bird's Avatar
Don't make fun of my little turbos!!!!
Old Apr 26, 2010 | 09:15 PM
Zombie's Avatar
Any idea why your STS setup spooled so pathetically?
Old Apr 26, 2010 | 09:20 PM
2ktransam's Avatar
I had a 1.15 exhaust housing on it and its on a Dynojet so it was hard to load.
Old Apr 26, 2010 | 09:27 PM
ZL1Killa's Avatar
had a 0.81 ar and had no problems loading the turbo...
what rearend gear did you have
Old Apr 26, 2010 | 09:39 PM
SincalT/A's Avatar
Seemed to be a temp difference between the dyno days also.You got a chart on the iat differences?
Old Apr 26, 2010 | 10:03 PM
2ktransam's Avatar
I have 3.73 gears in it. The .81 would have helped spool time but it chokes it up top so I had the big housing on it.
Old Apr 26, 2010 | 10:04 PM
2ktransam's Avatar
I don't have a chart but the iat's are about 35 degrees higher with the front mount on low boost. I run meth on high boost so it doesn't matter.
