National Speed: 2001 Pontiac Trans Am - Built LQ9 - GT4788 - 1,200whp+...
Old 06-19-2010, 09:28 PM
  #121
LivingCanvas's Avatar
Originally Posted by Phil99vette
Where do you set the rear tire on the dyno roller? For whatever its worth... When we dynoed mine we put it on the backside of the roller and used 6 straps on the back and 4 on the front. It held to 1200 without spin.
I've used dyno dynamics dynos where the strap comes up between the rollers and you actually strap to the rear end itself. Its pretty awesome because you put lots of tension on the actual part that you need to stay. Held a 1200lb ft cummins no problem
Old 06-20-2010, 01:47 PM
  #122
veee8's Avatar
We normally put the rear tires towards the back of the roller, only had 4 in the rear and 2 in the front. We will look into something different when it goes back onto the dyno.
Originally Posted by MUSTANGBRKR02
Well here it is leaving off the line. They only got two runs in (Rain).
Nice pic, we ended up getting a third run in too. Here is the rundown that I posted on rwhp.us
Overall, I am quite pleased with the first shakedown of the car. I mean the first time it really drove under its own power was around 3 am Saturday morning!
Boost was turned down to wastegate spring, which is 7.5 psi.
First pass on the virgin track, rattled the tires at the hit off the transbrake, I got out of it, then nailed it again, pulled strong through first gear. As soon as I hit second, the car spun and pitched sideways. At that momoent, rain covered the windshield, and it was a nice awakening.
Second pass, footbraked to a 1.45 sixty foot, ran mid sixes through the eighth, but at high speeds, the hood bowed up so much, it blocked nearly the entire windshield! I could not see, and got out at 800 ft. coasted to a 10.30 at 116
Third pass tried the trans brake again, but was gun shy, and didnt have faith the track would hold, so I didnt build any boost off the line, so a lame 1.8 sixty foot didnt net a great time, but it was the first full pass, and the 130 mph trap speed , would have netted a 9 sec. pass with a good sixty foot.
Keep in mind, that was all 7.5 psi of boost, we have almost another 20 psi still on tap, once we get a good boost controller on the car.
Good day at the track, and I still cant believe we pulled it off!
Old 06-20-2010, 05:04 PM
  #123
MUSTANGBRKR02's Avatar
I knew that too. That pic is of the third run. I guess i didn't really count the first one
Old 06-20-2010, 06:49 PM
  #124
Rickys S/C Z28's Avatar
damn man thats crazy power for 7.5 psi!
Old 06-20-2010, 08:39 PM
  #125
Shawn @ VA Speed's Avatar
let me know when you want me to come down and work my magic on that thing
Old 06-21-2010, 06:59 AM
  #126
veee8's Avatar
Next step is to get it ready for the Motor City Rumble in July. Definitely need a functioning boost controller for that....and maybe the Shawn, throw the timing at it, tune.
Old 06-21-2010, 11:21 AM
  #127
'Trust''s Avatar
Sick build. Awesome.
Old 06-21-2010, 11:51 AM
  #128
7 Second Club
Phil99vette's Avatar
Shiiitt, Shawn is Mr, we dont swing for the fence, conserative.
Old 07-01-2010, 07:08 AM
  #129
veee8's Avatar
Put it on the scales last night.
3369 lbs, wet, with around 7 gallons fuel, and 5 gallons of water in the ice tank and all fluids no driver. Not too awful for a filled iron block and schedule 10 equal length turbo headers. Stock carpet etc....
The AMS-1000 should be here today, then wrap up a few small bugs. Then it is on its way to Milan, MI for the GM High Tech Performance race on July 10th. Matt will be driving, I will be there to setup the car. Come find us to check the car out in person.
Old 07-01-2010, 08:28 AM
  #130
LS1Tech Sponsor
Superman09's Avatar
Well I'll be sure to make Milan on the 10th then to see this in action!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 07-01-2010, 10:08 AM
  #131
man i wish i could be there!!!!! good luck guys
Old 07-03-2010, 01:06 AM
  #132
veee8's Avatar
1037 RWHP SAE............Dyno sheet and video will be up soon..........
Old 07-03-2010, 01:14 PM
  #133
veee8's Avatar
Old 07-03-2010, 03:07 PM
  #134
396D1SS's Avatar
wow, nice shop and build!!! looks like your shop has its **** together!!
Old 07-03-2010, 03:18 PM
  #135
blackonblacksls's Avatar
seems like the guy from Forced inductions was right on the money when it came to what the turbo is going to put out.
Old 07-03-2010, 04:01 PM
  #136
veee8's Avatar
Not really. We are still on a conservative tuneup. With a small 1.08 A/R housing. There is another 100-150hp left in it when we feel the need to lean on it.
Old 07-03-2010, 04:49 PM
  #137
Dogsofjune's Avatar
Originally Posted by -Q-
That is some serious engine **** right there.
X2. Nicely done.
Old 07-03-2010, 04:54 PM
  #138
355TurboLT1's Avatar
Congrats on the numbers! Im really curious what my GT 4788 will do with the billet wheel. If I remember Precision said it would do like 100+ hp over the cast wheel and spool a bit faster. Only one way to find out.
Old 07-03-2010, 05:14 PM
  #139
droksformula's Avatar
Thumbs up
Don't be a tease, what where the peak boost and timing #'s ?
Old 07-03-2010, 08:11 PM
  #140
Not at all the car has more in it.
Quick Reply: National Speed: 2001 Pontiac Trans Am - Built LQ9 - GT4788 - 1,200whp+...
