Finally going FI. Need a little advice.
#44
Yea no doubt will. Just trying to tie up some loose ends on my end from still being a noob at turbo stuff. Once the motor is together which should be about a month i will start cutting, and building the kit in the car with details. Im sure i will link it in here.
#45
Got some pushrods, and got a timing chain. Found out that the 80lb. Siemen injectors with a stock PCM will work just fine as long as i have a big fuel system which I already do. Also called up Jose @ Forced Inductions and he speced me out a turbo. He recommended me the GT91 T-6 turbo. Its one of the budget turbos offered by Garrett apparently and I think he said the price was only 1350 bucks which is a hell of a lot cheaper than i thought.
Another question for you guys. What size Wastegate, and Bov do i need? Also what exact brand, and everything like that as well. Also why do some guys run 2 BOVs? Also what boost controller?
