Procharger oil check
Conan, you might be right about the cable not reaching the bottom. I will try to take a look at that this weekend when I get a chance. It's just so $^@# hard to get to.
I'm not too worried but at the same time I'm not real sure what happens if there really is too much oil in the supercharger. The same thing goes for the motor oil. I don't know what happens when you overfill it. I can't imagine it hurting anything, but at the same time I don't think they'd warn you not to overfill it if there weren't any consequences.
dipstick has to be screwed in-is your supercharher clocked correct?
the drain plug has to be at 6 o clock for the oil slinger to work
you might be better off draining it again and starting over, and pour in the correct amount, then ck the dipstick, better wasting a bottle of oil than the supercharger-also pull the stick before draining
I went to Home Depot and bought the smallest diameter tubing that they had hoping it would fit into the hole. I ran it down to the hole and thought it was in there to start with, but apparently it wasn't "in there", because I barely moved while I was pouring the oil in, and the next time I looked down I saw that my tube was not in the hole anymore and there was a puddle on the ground.
Yes, the drain looks to be around 6. I did think about draining it and trying again, but I don't have anymore oil so I'll have to order some. I just remembered I was changing the motor oil at the same time and had the car jacked up on one side so I probably kept some oil in the s/c that I didn't know about. I also did not take the stick out before I drained it.
Do you guys normally get some metal on your plug when you change the oil? It is my first time with this so I'm not sure if it's normal. Thanks.
-Zeke
-Zeke
This is the screwdriver set I have. See the hex nut under the handle, you can use a wrench to help turn the screw driver while you push down on the screw. The big one in the middle is the one I use for the blower screw its a 1/4 by 12'' long.
http://www.amazon.com/gp/product/ima...5964550&sr=1-1
-Zeke
