turbo spark pulug and gap
I plan on running about 24#'s of boost (max, and normally probably around 18-20#'s). I also plan on running 93 octane plus meth injection on a 8.8:1 CR.
I cross referenced and it looks like;
Autolite Spark plug
NGK 5671A-8 is Autolite 2614
NGK 5671A-9 is Autolite 2612
Which would be better for my application to start and would .22 gap be appropriate?
Side gapped recessed plug VS a standard protruding plug (and no those aren't my mangled fingers
Autolite AR474 "racing plugs" are what I would run for most 20+psi LS motors. If I didn't need a resisted plug I'd be running them. Best performance plug for the money IMO. They are an "8" heat range on the NGK scale. Also have a "special" electrode material. My local parts stores could order these cheaper than summit/jegs.
http://www.summitracing.com/parts/frm-ar474
http://www.ebay.com/itm/6x-NGK-Coppe...-/231063736637
Rock auto has them under $3.
https://www.rockauto.com/dbphp/x,cat...,NGK_5430.html
I just need to find a good plug for my application. I was hoping Martin from Tuck would have chimed back in with me by now.
If you are shooting for 1000rwhp with 8.8:1 compression a 8 heat range plug should also work for your usage. That said, you may find that if you read a fresh set of plugs that were shut off at the end of a run/pull that you could end up needing a 9 heat range plug.
https://ls1tech.com/forums/nitrous-o...o-read-me.html
Autolite Spark plug
I just wanted to verify this with you and get a confirmation that I should indeed try the Autolite 2624 first, and then try the 2612 as you mentioned for appropriate heat range.
