How much HP will 60-1 hifi support?
Hello, all. My first post on the forum.
Any idea how much HP or airflow a Turbonetics 60-1 hifi can support? I'm making 407rwhp/500rwtq on an LT1 at 10psi and have to use the SMC alky kit to suppress detonation. Just wondering if I'm at the limits of compressor efficiency.
I've yet to measure post-intercooler temps to see if they are high. Just thought I'd ask to see what you guys thinks. I've seen mention of T76 upgrades on older posts and wondered at what point this was necessary.
Thank you!
Thank you!
The best I've ever seen is a guy here in Detroit. He tuned his Mustang with a 302, full exhaust and a TTi 60-1 hi-fi on a Mustang Dyno to the tune of 500 RWHP although it may have been something better than pump gas, I don't know.
Like I said, that's the best I've seen. Realistically, I think we may be talking closer to 450 on a dynojet, which is roughly 90rwhp less than the above example.
SC-
SC-
Thank you!
Thank you!
I say if you wanna easily make over 500RWHP get a T76.
Originally Posted by Mekkadon
well, I have heads/cam/forged internals. I'm making 470RWHP on a mustang dyno in my automatic/vig3200. 10PSI w/93 oct. I have the TurobTech T60-1 kit.
Thanks for the replies!
The 60-1 hifi is good to a bit over 600 flywheel hp without getting too far out of the efficiency range.
interesting comparison pic
qmp 63mm vs t-60 hifi.
http://community.webshots.com/photo/...64995007IhNxDq
http://community.webshots.com/photo/...64995021pyovwo
What are the specs on your engine? Making your motor more efficient NA would help you make more power with FI. FWIW, I'm running 7lbs(60-1hifi) on my low cr 383 lt1 with stock timing, and have no detonation. MM&FF made over 750hp on a 408ci ford with a t66, and 7lbs of boost.
I get high RPM miss only under high boost levels (10psi) above 5,000 rpm which is either an ignition problem (I've replaced everything and run a Crane HI-6R) or a lack of airflow or fuel. Fuel pressure never drops do I thought it might be the turbo maxing out. Kinda shooting in the dark on this one.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
What are you running for a cam? And what have you done with the timing? Are you retarding it under boost?
Originally Posted by turbolx
Nope, just regular ol' Amoco 93 octane and a good tune. In fact, that is a STOCK 60k+ mile 302 bottom end under it and it's been living fine that way for the last couple years of road racing, drag racing, and daily driving. I guess I could make more if I put it on a real engine.
SC-
SC-
Originally Posted by MYTURBOT/A
What plugs are you running? Gap? Do you have any KR?
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
I think your probly maxed out at what your engine will flow at your current pressure ratio. Get some good heads and intake like the lt4 conversion kit with ported heads and intake and you`ll max the turbo out at about 500-525hp.
