Trex cam + boost results
Sorry almost forgot, stock bottom end LS1 2004 M6 GTO
This is a friend of mine's car we just got everything all together to make a few pulls and take it to the track. I tuned the car with the procharger setup but I didn't do the previous N/A tune. Stock bottom end LS1.
Naturally aspirated mods
Trex cam 242-248 110 LSA (Not even close to a boost cam)
Fast 90 intake
New Era CAI
Pacesetter headers with stock exhaust
LS7 Clutch
New mods
D1sc procharger 9-10 psi (hard to make boost with 25 degrees of overlap)
LS6 intake with ported t/b
Devils Own methanol kit
Magnaflow exhaust with no cats
3.91 gears and aluminum driveshaft
60lb injectors with single walbro, need another one
2 Bar SD tune
Look how much torque it gained at 3000 rpm! 500 rwtq from 4800-5900 rpm, thats a Trex cam for ya lol. Now we all know this is not the right cam at all, he will be building a 408 in the near future built for boost. This was just to see what we could do with the LS1.
With a better 60' we will have his car in the 10's soon. Best pass so far is a 11.32 @ 126 with a 1.74 60'. 2200' elevation and 3000' density altitude.
http://www.youtube.com/watch?v=ztWKVR_0DQI
and only 9lbs of boost with 11-12 degrees of timing. It still has more in it but the damn meth works when it wants to. Luckily I had a lot of safety factors tuned in the car incase the meth failed it wouldn't blow the stock motor.
As far as a sound clip it's not radical sounding, you cannot even tell it has a big cam at all with the dual 2.5" magnaflow setup. It sounds insane when he gets on it though, very loud. Next time I go over I will get a sound clip though.
