which head gaskets to lower compression?
Im using an iron 346 fully forged with a set of stock 317s the compression of the motor alone is 10.1 but ill be putting the stock 317s on and i need the lowest compression possible.. which gaskets do you guys reccomend?
thanks
thanks
The 317 heads will get you down to around 9.4 to 1 if you use a stock thickness head gasket. Stock thickness is about .052 compressed. Be sure to use a MLS style head gasket and it will need to be for the 6.0 open chamber heads.
