new dyno numbers, power loss through a muffler?
Car is stock shortblock, TC76, stock 317's with patriot duals, ls6 cam, etc etc. Runs like a champ. ZERO complaints
Dynoed in oct when i finished the setup. 9#'s of boost and 17 degrees of timing. roughly 75 degrees ambient. did 542hp/555tlbs.
fast forward to setup today. 11#'s of boost, 15 degrees of timing. and added a muffler to the once open downpipe because i didnt like the sound at idle. not gonna lie, the muffler is substantially larger than i thought and i didnt really like the size but i already bought it so whatever. roughly 105 degrees ambient in the shop. 523hp/550ftlbs.
i figure some of the difference is heat but i figured id be 560-570 with the added boost and minimal drop in timing. could the muffler really be killing that much? its coming off tonight just in case but this is more curiosity talking
cutout? bro i have a TC76 front mount TA as well and when the cutout is closed it runs like a stock car. but when i open it, it goes into INSTASPOOL mode! i have a 3" downpipe that goes to a cutout under the passenger seat then into a Hooker Aerochamber catback. i will get track times at 11 psi open and closed. there is a huge difference in power. you drove it open downpipe? your poor ears.
i went out today and tried my 2 step with the cutout open and closed. with my 2step set to 3700 rpm and ambient temp around 103 degrees, it built 103 kpa WOT with the cutout closed. with it open it made 126 kpa and got the cops called on me for a noise violation.
Bigger *** muffler , Less timing and very hotter weather sounds about right.
Was the old runs with the same A/F Ratio?
I know your running very safe A/F Ratio for the stock short block but I really think you can get more power with 11.2 - 11.5 A/F Ratio..
Keep us posted.
Keep us posted.
