Can I get this death turbo to spool?
Ya I was j/w if anyone knew what rpm it would actually spool at. I know its not going to be streetable. My main question is what c.i. motor I would have to have to spool like 15 psi or so by like 3500- 4000
you can make it fit. just do it intelligently and simply as you can. it may not work well with the 347 but you can use it until you get the funds for a 408 and make some serious power with it!! if you have concerns about spooling you can always increase compression and go E85 to battle knock.
Personally I'd get rid of that turbo and go for one which is known to work like an S380/S480. A 1.10 T6 S480 shouldn't spool that bad on a 346. Spend an extra $500 for a SP quickspool valve and the car will be a rocket.
#33
