FMIC - Anyone have install pics?
I'm replacing a Procharger standard 2-core FMIC that developed a leak with a Mishimoto unit. Anyone have install pics showing the front end off and how they mounted their FMIC? Pics are greatly appreciated!
Do you have any pics showing how you bolted it up? I'm trying to figure out if I need to weld 4 custom brackets, 2 custom brackets, or make use of something that's already there. It's hard to see in the pics if you're using the IC's threat mounting studs or not.
Yep, I see now. Thanks! Do you see any need for some type of bracket underneath hitting the lower IC mounting posts to take the weight off that plastic?
I thought about welding two Z-shape brackets underneath the frame to come down and catch those two mounting points. It would basically provide a shelf for the IC to sit on. Then using holes drilled through the plastic just to provide a little bit of top support without putting stress/weight on the plastic.
LS1Tech Sponsor
Shoot me an e-mail to brutespeed@gmail.com and I'll send you some installation instructions that may help you out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Give me your e-mail address, when you e-mailed me the return address was LS1tech. noreply@ls1tech.com Bob
__________________
LS1Tech Sponsor
...and if that doesn't work send to Ryan.parthemore@gmail.com
__________________
Any issues with re-attaching the nose without the front bumper support or with the front bumper support cut out like XtremeDime, TX RED and Tally TransAm? Isn't that what the bottom piece pf plastic reaches up and connects to? I already forget from yesterday.
