Pistons for Boost
Old Jan 20, 2004 | 06:55 PM
SSnakekiller's Avatar
Default Pistons for Boost
I blew my stock pistons/rings boosting and I need to know what I should do about replacing them. I dont have the option to do anything but new pistons. What should I go with? I dont mind getting boost pistons to lower compression a bit.
Thanks
Old Jan 20, 2004 | 10:12 PM
anyone?
Old Jan 20, 2004 | 10:30 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Diamond Pistons for sure! Most guy's on this board are running them if they have replaced pistons. Give me a call and we can dicuss what you need. You also can get them direct through me. They have a couple blower/turbo pistons on the shelf. You might be able to use them.
Thanks,
Old Jan 21, 2004 | 10:20 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am running 719rwhp with the Diamond -8.6cc FI pistons.
Old Jan 21, 2004 | 01:45 PM
Crunch's Avatar
I use the same pistons. Pictures on my webpage.
Old Jan 21, 2004 | 03:44 PM
BoostJunkie's Avatar
Restricted User
I bought Diamond pistons for my engine and had to send them back to be remachined because the skirts hit the counterweights on the crank. Not very good attention to detail for an $1100 set of pistons if you ask me.
So now I have a $400 bill from my engine builder for disassembly of the rings/rods and removing the crank from the block and re-balancing after the pistons are remachined because they are lighter now. Chris at diamond also promised me 1 day turn around on the remachining, but he quit Diamond to go work for AP and just left my pistons sitting on his desk and never scheduled them to be remachined. If I hadn't called looking for them who knows how long they would have sat there as a paper weight.
Evidently with Diamond I didn't get what I paid for.
We will see if they reimburse me for my out of pocket expenses resulting from their screw up.
Old Jan 21, 2004 | 03:45 PM
BIGBOS's Avatar
I'm using diamonds as well.......
Old Jan 21, 2004 | 09:11 PM
Boost junkie, sorry about the pistons. They arrived to Diamond the day I left. So there was not much I could do about them. To be honest with you I did not even see them show up. If so I would have scheduled them to be fixed and turned them around in one day for you. On Diamonds side they are doing what they can to get you fixed up and back on track. Once again, I apologize for not being able to see them through for you. I am sure that Diamond will overnight them back to you.
Old Jan 22, 2004 | 09:19 AM
Restricted User
Chris, no problem, if you were already gone there was not much you could do.
Diamond did however get my pistons shipped out to me this morning.
And low and behold they are not machined correctly, they only took material out of #8 piston on 1 side, didn't even touch any of the other pistons.
So now I have a voice mail in to Ron to see who screwed up this time.
Old Jan 22, 2004 | 12:41 PM
doc2121's Avatar
Diamonds here
Old Jan 22, 2004 | 12:57 PM
Time2Kill's Avatar
MASS seller approved
Looks like your on the same track that I was with Diamond. First set of pistons were not clearanced for the reluctor wheel. Had to send them back to be remachined, and when I got them back and installed, they came 1/4" out of the block. They used the wrong compression height. They made me a new set of pistons again and made the same mistake. Finally got it right on the 3rd set of pistons. Took almost three weeks after I received the first set of pistons to get everything right. Kind of dissappointing after spending $1100 on pistons.
They're some of the best pistons on the market, but trying to get them can be a pain in the ***.
Old Jan 23, 2004 | 08:10 PM
Sorry again guy's for the mistakes. Since I am no longer at Diamond I am not sure how much say I still have left. I will see what I can do. Hopefully we can eliminate these problems in the future.
Sorry
