centri mounting question
Old Jul 28, 2010 | 01:13 PM
Bullitt4110's Avatar
Default centri mounting question
I am doing a LQ4 with LS1 F-body acc drive in my Chevelle and was wondering if there was a centri bracket system that mount it similar to C5/C6 set-up? The steering box is right were the blower would mount with a standard f-body set-up. Would sometime like a A&A bracket with longer spacers (due to the f-body acc being spaced out father than the C5/C6)? Thanks.
Old Jul 28, 2010 | 02:46 PM
pist0lpete's Avatar
The best setup I could figure that would work on a chevelle is a GTO setup. I realize that would require switching to the GTO drive accessories but it hangs the supercharger out over the fender on the driverside out of the way. I believe it should bolt in but may require some inner fender modification.
Old Jul 28, 2010 | 02:48 PM
dschmittie1's Avatar
Procharger might have a ls bracket set up for LS swap stuff
Old Jul 28, 2010 | 04:45 PM
KS91Z28's Avatar
Sounds like the perfect candidate for ProCharger's LS Transplant brackets. http://www.procharger.com/LSxTransplant.shtml
Old Jul 28, 2010 | 09:20 PM
Ok that's interesting but I was wondering if something would work with the f-body acc drive, because if go to the trouble of buying another acc drive I'll just get the corvette one and do a A&A or Ecs bracket but I'd rather not have to buy another acc drive.
Old Jul 28, 2010 | 09:28 PM
kikass_z28's Avatar
corvette accesories with 'flip drive' gets my vote
Old Jul 28, 2010 | 10:31 PM
danbap's Avatar
the gto bracket will work with f body accessories. thats what im running.
Old Jul 29, 2010 | 12:55 AM
Have any pictures? Ill have to look into this set-up.
Old Jul 29, 2010 | 06:02 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The ProCharger transplant kits were designed for applications such as yours.
Here is a link to these systems from my website.
http://shop.brutespeed.com/LSx-Trans...ne-Kits_c3.htm
I also sell the GTO bracket assembly if you decide you want to go that route.
http://shop.brutespeed.com/ATI-3GNBB...-3GNBB-002.htm
http://shop.brutespeed.com/ATI-3GNSP...-3GNSP-001.htm
Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Last edited by Bob@BruteSpeed; Jul 29, 2010 at 07:10 AM. Reason: Added ProCharger GTO Bracket Assembly
Old Jul 29, 2010 | 08:43 AM
pist0lpete's Avatar
Bob-How does the swap mount sit compared to a GTO mount? I ask because I have seen a GTO setup in person but not a swap mount.
Old Jul 29, 2010 | 08:50 AM
LS1Tech Sponsor
https://ls1tech.com/forums/forced-in...stay-away.html
Take a look at the above link. Thanks. Bob
__________________
Old Jul 29, 2010 | 10:05 AM
pist0lpete's Avatar
Thanks that gives me a better idea. I am thinking minimal mods to the inner fender.
