QMP Turbo Formula - 750rwhp / 830rwtq STOCK ENGINE
Old 01-23-2004, 07:48 PM
  #81
jleews6's Avatar
I had alky on a buick 3 years ago and we did a little test.
With 15# of boost on pump gas it would get about 3* of retard and all we did was install an SMC. alohol kit and within 15 minutes of tuning on the highway we were at 21# of boost with the same timing and no knock at all this was still on sunoco ultra 94.
The only downfall to this was that we had to spray alot of alky and the tank would run out quick.
With this setup we ran a high timing (25*) race chip all the time.No need for c16.
jleews6 is offline
Old 01-23-2004, 08:13 PM
  #82
ArcticFormula's Avatar
How much for a de-tuned version with say 450rwhp?
I have a Formula which would love some of that .
Awesome numbers!
Regards,
ArcticFormula is offline
Old 01-23-2004, 09:46 PM
  #83
1CAMWNDR's Avatar
Rob, did you guys ever change the valve springs?
I can't imagine what this thing could do with a turbo cam (even a mild one) and an LSX intake. Great numbers. Not what us average Joes need to be trying; but stunning all the same. Seems a stone stock LS1 with proper tuning and the alky system could survive 550-600 rwhp forever.
1CAMWNDR is offline
Old 01-23-2004, 10:30 PM
  #84
MYTURBOT/A's Avatar
Last i herd the lsx intake provided little to no gains over a ls6 intake. Rob have you maxed out the MAF yet?
MYTURBOT/A is offline
Old 01-23-2004, 11:57 PM
  #85
69firebird's Avatar
yeah,
the numbers for the LSX intake arent that impressive. most ive seen was like 13 rwhp. not worth 6bills. ifyou allready have a turbo . I however have a sheetmetal intake so I suppose i am dumber than those who buy the LSX.
ed
firebird455@onebox.com
69firebird is offline
Old 01-24-2004, 01:10 AM
  #86
eviltwins's Avatar
Originally Posted by y2khawk
. it also makes it possible to claim "pump gas" It's an octane boost as well.
Personally, I consider running pump gas + meth more streetable than needing C16 to make the power wherever you go. Atleast with an alky injection kit you can cruise around only burning 91/93/94, and then when you hit it the octane is there.
eviltwins is offline
Old 01-24-2004, 01:40 AM
  #87
The Guy in MY 99TA's Avatar
I'm drooling! I just wish I could afford a turbo set up. MAYBE one day when I get out of school and stuff.
Josh S.
The Guy in MY 99TA is offline
Old 01-24-2004, 04:00 AM
  #88
97M6Formula's Avatar
I wanna see avideo
97M6Formula is offline
Old 01-24-2004, 04:46 AM
  #89
Moderator
Black LS1 T/A's Avatar
Thumbs up
That IS unbelievable! You are about to make me wish I had a QMP Turbo.
Great job!
Try to keep it together, though. It's rather pointless to build a car to break it the first time out. I would like to see what it would do, but have longevity.
Certainly, the guy that said it won't hook is correct... but with that kind of mad power and horse-power curve, you may make up for it on the big end enough to still pull a stunning E.T.
You will need at least something on the par of ET Streets. I drove my car from Raleigh, NC to Huntington, WV last weekend and a guy tried to race me driving 70 MPH. With my Nitto 285's, I broke traction so badly that I felt foolish trying to race it without drag radials on. Quite dangerous when your tires break loose at 60 to 70 MPH. I had 549 RWHP / 757 RWTQ at 9 to 10 PSI peak. I don't know where it's at now that I am maintaining 13 to 14 PSI. But it has mad power. I need to get the CAS regulator and modify the line up front so I can get more fuel flow. (I'm still running this on 93 Octane and lowered timing.)
Keep on truckin', baby!
Black LS1 T/A is offline
Old 01-24-2004, 05:35 AM
  #90
y2khawk's Avatar
The way i look at it, $3.50 a gallon for 110 or even $8 a gallon for C16 is cheap compared to the money spent to make the power.
Then again, i can get 110 at the local station year round, and the C16 is only a couple pumps of the drum away
To each his own
y2khawk is offline
Old 01-24-2004, 07:23 AM
  #91
cablebandit's Avatar
damn....110 local is sweet!!! I was buying xylene by the drum..only got me 100 octane i think but was better than 93
cablebandit is offline
Old 01-24-2004, 07:49 AM
  #92
Shorty Director
VINCE's Avatar
If the alchy injection/methonol can be used on the supercharged cars I think Rob is on to something for the ls1 crew..
VINCE is offline
Old 01-24-2004, 08:42 AM
  #93
I8Your03Cobra's Avatar
And i thought 8psi was a lot on the stock block
I8Your03Cobra is offline
Old 01-24-2004, 11:05 AM
  #94
ChevyNo1's Avatar
OK . . . so we've established that methanol likes to eat stuff. So what does Rob for example have to lose by running methanol? Was that particular kit designed to flow methanol? I've got the SMC kit, and I emailed and asked about running methanol in it. He said if I had the square tank, then yes, but if the round tank, then no. Even if the kit can take it, what stock components on the car are at risk?
- Dug
ChevyNo1 is offline
Old 01-24-2004, 01:10 PM
  #95
Rob Raymer's Avatar
We are also using alchy on the -dare I say- supercharged Fords with huge success. I'm putting a kit on my Harley truck as we speak. Of course it's a roots blower, but it's still nice to see it works with 'other' boosted apps. We've had customers report back gains of 20-40rwhp on the Lightning Trucks with alchy alone (no methanol).
Just for informations' sake, I'll let you know when we dyno the results of it on our Harley Truck. Should be interesting.
FWIW, all of the alchy kits we sell have the quare tank, so they will all work with Methanol.
Our next step on the Formula after we change to a doublepumper, billet regulator, and billet rails, will be to try straight Methanol. We only ran a 50/50 mix of Meth and Alcohol this time on the dyno. Plus some slicks....maybe we'll see 800+rwhp??
BlackLS1TA - I would bet that you are making some SERIOUS power also. You should get it back on the dyno soon.....who knows....maybe you're making more than me!
BTW, we can also buy Turbo Blue atthe pump right down the street from us, which is why I used it. But the really nice thing about the alchy kit, is the fact that you only use it when you floor it. Rather than driving around on $350/gal fuel and maybe never even needing to floor it.
In example, I drove the Formula on a road trip a few weeks ago, and when I left the house, the alchy tank was full (a whole 1/3 gallon equal to $3). We drove over 600 miles roundtrip and when I got home, it was still half full (<--optimist). So I used only $1.50 worth of alchy and still managed to whoop up on a single turbo'd Supra during the trip. Sweet I say.
Rob Raymer is offline
Old 01-24-2004, 01:13 PM
  #96
Rob Raymer's Avatar
Oh, I almost forgot to thank Mightymouse for his post (after I got up off the floor). I printed it out, framed it, and I'm going to hang it in my office over my desk....right next to the dyno sheets.
Have a great weekend everyone.
Old 01-24-2004, 01:26 PM
  #97
ChevyNo1's Avatar
Cool info Rob. I am going to have to upgrade to the square tank and move it up to the front of the car, instead of in the trunk!
- Dug
ChevyNo1 is offline
Old 01-24-2004, 05:15 PM
  #98
Excal's Avatar
GM hightech should jump all over this...or somebody
Excal is offline
Old 01-24-2004, 07:26 PM
  #99
SStroked 410's Avatar
Nice numbers!!!!!
If you only ran the 340 intank how much rwhp/boost could you run "WITHOUT" the alchy? Just trying to get an idea how much rwhp these 340 intanks can take.....650-700rwhp max maybe?
SStroked 410 is offline
Old 01-24-2004, 08:12 PM
  #100
600rwhp is about the limit imho with 10 gauge wire from pump to the front on walbro 340
Quick Reply: QMP Turbo Formula - 750rwhp / 830rwtq STOCK ENGINE
