Making the switch from Procharger to Turbo
Old Feb 10, 2011 | 01:52 PM
  #61
N2OBaby's Avatar
Thumbs up
Nice Turbo hookup.
Keep us posted.
Old Feb 11, 2011 | 03:44 PM
  #62
Fireball's Avatar
glad to see you're making a comeback...
just make sure you account for all bolts and nuts this time before firing it up
Old Feb 11, 2011 | 04:08 PM
  #63
dschmittie1's Avatar
yeah yeah yeah. It figures as many engines as I have had apart working in a dealership for the last 8 years I do it to my own motor.
Old Feb 11, 2011 | 07:31 PM
  #64
Monte4ever's Avatar
S&!T happens.....Its how you come back that matters.
Old Apr 1, 2011 | 03:27 PM
  #65
Well it has been one thing after the other with getting held up with the motor. Lets rewind back about 6 weeks. Drop new block, crank, 1 new piston 7 old pistons, and my callies H beam rods off at the machine shop. one week goes by and I get a phone call saying I have 3 pistons with colasped skirts ok so I order 3 more pistons takes a week to get. Drop 3 new pistons at the machine shop and it takes them 1 week to get back to working on it. Then I get a phone call saying the new pistons are different than my old ones. Skirts are longer and they are 8 grams heavier. They also said that the difference in the skirts isn't the 8 grams so they changed more in the piston. So takes a few days back and forth with Diamond and the agree to let me send the 4 individual pistons back and get a full set as it is MUCH cheaper. Plus had I know that the pistons changed I would have ordered a whole set up front instead of purchasing individual ones. Also pisses me off that they would change the piston and not change the part number. So fast forward to this week. I got my full set of pistons from Diamond but now it is my turn to hold things up with the motor as I made the decision to Upgrade my rods as I discoverd this week that my Callies H beam rods are only rated for 750 hp and I hoping to be in the 900-1000 crank hp range.
So what started out as a new block and refresh the motor. As basicly turned into a complete new motor. Here is the run down.
LS1 block
Stock cranks
Callies HD I beam rods
Diamond -8.6cc dish piston
Virginia Speed VTC-2 cam
AFR 205 66cc heads
Ported Vic JR and Aarrons Elbow (matched to heads)
Gonna be around 9.6:1 CR and hoping to push 12-18 psi at it once I get all the little stuff worked out. I am planning on running pump and Meth for the 12-15psi range but gonna switch over to race fuel for the 18 psi stuff. If we had more than 1 local gas station(and its not really close to me) that had e85 I would probably run that all the time
Old Apr 1, 2011 | 04:50 PM
  #66
1fast bird's Avatar
If you need to blame me for the whole wrong rod thing you can
Old Apr 1, 2011 | 06:20 PM
  #67
I am not gonna blame you but seeing how close your motor was to its guts out. It is money well spent to help fight off the need to build another motor.
Old Apr 26, 2011 | 10:09 PM
  #68
Well time for a good update. Got all my parts back from the machine shop last Thursday.
Callies Compstar I beam rods
Stock block with APR studs
Stock crank
Everything was machined, balanced, and bearing clearances checked at the machine shop to all I had to do was put it all together
Using a rod bolt strecth gauge.
Head studs in
LS9 head gaskets
AFR 205 heads installed
Got the motor all together Monday at work. So monday night and Tuesday night I got the motor and trans all bolted together at home and ready to go in the car.
Motor and trans will be in the car Thursday night and I plan on hearing it run Saturday. Still have LOTS of little things to button up before it is driveable but it is getting close
Old Apr 27, 2011 | 07:20 AM
  #69
evo462's Avatar
Does the downpipe clear your steering linkage OK? Just wondering, because I am also routing my smaller (3") downpipe out the driver's side with a tubular K and by just eyeballing it, a larger downpipe looks to be a tight squeeze.
Old Apr 27, 2011 | 07:24 AM
  #70
Yeah it clears my my steering shaft. It is close but it clears. This turbo set up was already installed in the car with my old motor just never ran
Old Apr 27, 2011 | 02:27 PM
  #71
RacerXLs1's Avatar
Looks good, cant wait to see some numbers...
Old Apr 27, 2011 | 07:51 PM
  #72
yessir's Avatar
waitin on ur 9.6 @149 shakedown run at 13 psi
Old Apr 27, 2011 | 07:55 PM
  #73
JAX04's Avatar
WOW! Great work man! she looks great!
EDIT: How do you like those AFR 205s with boost?
Old Apr 27, 2011 | 09:31 PM
  #74
have not run the car with them yet. They are new to me. Just picked them up at the last issues damaged one of my 243 heads that I was running before.
Stock casting heads did really well for me before with boost. I know everyone likes the 225 AFRs for boost but I got a great deal on these other wise I would still be running a stock casting heads.
I think the car will do really well with these heads. Should be a monster.
Old Apr 29, 2011 | 01:11 PM
  #75
simpleboy77's Avatar
Originally Posted by dschmittie1
LS1 block
Stock cranks
AFR 205 66cc heads
Can you explain how you get 9.6:1 CR whit this ? I did it on some online program and i'm at 9.32:1
Old Apr 29, 2011 | 02:06 PM
  #76
Well last time I used a calculator with my old set up and a 64 cc head I was around 9.9:1 I also no I was around 9.5 with my stock 241 heads which are 67cc.
I just ran the numbers again.
3.905 bore
3.622 stroke
.051 compressed gasket
piston is 0.01 out of the hole
66 cc heads
-8.6 cc dish
gets me 9.6:1
Old May 2, 2011 | 10:02 PM
  #77
figured out one of my issues with the car and running. Found a ground I missed when putting things back together. Also spent some time working on the idle VE so that it will stay running. Here is a start up vid.
http://www.youtube.com/watch?v=vCIsQlmPgcU
I plan on getting the caf on the ground and loaded up on the trailer tomorrow night so I can take it into work and align and inspect it(expired in April). Hoping to be street ready saturday so I can start working on the tune.
Old May 3, 2011 | 07:08 AM
  #78
Fireball's Avatar
3.905 bore
3.622 stroke
66 cc heads
-8.6 cc dish
gets me 9.6:1
I calculate 9.6 as well...should be a quick-spooling ****
Old May 3, 2011 | 07:17 AM
  #79
That VA speed cam should help too
Old May 3, 2011 | 07:21 PM
  #80
383camaroz28's Avatar
Hey dan, whatd you use for radiator hose?
