Making the switch from Procharger to Turbo
Plus if I knew I could get traction in this thing I would give ya a run on the street. haha.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I was thinking about hangin part of it on the wall
Now that I am home from Ocean City cruise weekend it is time to start working on some WOT tunning. Should be track ready in about 2 weeks
1st
1.961 60'
7.49 1/8
106.26 mph
11.244 1/4
113.10 mph On the brakes
2nd
1.943 60'
7.54 1/8
103.71 mph
11.233 1/4
134.89 mph
3rd Left off the trans brake at 3200rpm saw 3 psi spun and peddaled it
1.970 60'
7.257 1/8
107.04 mph
10.966 1/4
124 mph Let off before the 1/4
4th Pass at the suggestion of Fireball I upped the 2 step to 3800rpm saw 4 psi on the brake. And Spun BAD out of the hole aborted the run.
Over all it was a good learning experiance for my first time out with the turbo. I only saw 8.5 psi all the runs. Looking back at the logs I shifted into 2nd just over 5k rpm and shifted into 3rd around 5800rpm. I was also lifting in 3rd at the big end. 2 of the 3 logs showed me lifting to 80% throttle in 3rd when I makign some passes. I syked myself out on the first couple passes caues it had been 1 year since I had made a pass in my car and this was one completely new setup so I wasn't sure what to expect.
Hoping to get back in the next few weeks on a better preped track.
Glad to see you finally got it buttoned up to enjoy it, afterall thats more important than setting records or new best. The Best V8 Stories One Small Block at Time
Glad to see you finally got it buttoned up to enjoy it, afterall thats more important than setting records or new best.Thanks it was a lot of fun to build
325 50 15 MT radials
I am having some issues with the 2 step causing the car to break up under boost so I ended up removing it last night for my last 2 passes so No trans brake launches and only did some light foot braking. Got my last to passes by MPH.
All passes were on 8.5 psi and my 325 50 15 MT radial. I need to work on the suspension more to get it dialed in to hook on the radial. Also on the foot brake launches I was not into boost at the line and the car didn't come alive until 60-80' out
My 2 full passes were as follows
1.946
7.124
106.99mph
10.749
136.86mph
1.819
7.037
109.48 mph
10.596
139.27 mph
Once I get the suspension sorted out and the 2 step issue figured out the car should do easy 9's.
also noticed today when unloading the car that I have an exhaust leak at the flange on my passanger side manifold to crossover. Gonna get this stuff fixed and get a manual boost contoller and head back to the track.
Here are a couple GOPRO video's form last night
http://www.youtube.com/watch?v=vpdYc0GVrzQ
http://www.youtube.com/watch?v=cOcT-fKS0W8
http://www.youtube.com/watch?v=KEb1WvuxXD4
Went back to the track last night. Still having issues with the car breaking up with my LPE 2 step installed. Run great with it removed. I have done everything LPE says to try and fix the issues and it still gives me problems. waiting to hear back from them now
Did get a new best with this set up still trying to work the bugs out. Here are the passes
1st pass
60'- 1.705
330- 4.505
1/8- 6.751
mph- 109.38
1000- 8.697
1/4- 10.338
mph- 137.82
2nd
I didn't get a slip said I left too late as I was trying to get up on my 2 step that I set at 7300 rpm instead of 3700 rpm
3rd
60'- 1.787
330- 4.556
1/8- 6.839
mph- 107.04
1000- 8.817
1/4- 10.474
mph- 136.70
4th (first pass with 2 step removed note higher MPH, not sure what I was thinking and went WOT on the foot brake and pushed through the lights
)60'- 4.140
330- 7.073
1/8- 9.328
mph- 110.00
1000- 11.251
1/4- 12.870
mph- 139.75
5th (I also lost my Alternator belt somewhere a the begining of this pass. Oh well)
60'- 1.656
330- 4.423
1/8- 6.659
mph- 109.81
1000- 8.580
1/4- 10.189
mph- 140.87
I know I short shifted out of first and second on this pass as I never saw the shift light light up
10.18 pass
http://www.youtube.com/watch?v=nkRs_BzlCVY
10.3 pass
http://www.youtube.com/watch?v=2jAvuiozRLE
