Any maggied ls1's out there??
Old 08-24-2010, 12:27 AM
firechicken76's Avatar
Originally Posted by 2000navyws6
No, just pump gas. I also have a ls7 clutch with the ls2 flywheel. lol yea i didn't plan on putting the blower on before I did the heads/cam package. I know its not ideal, but so far its been awesome. I'm interested in seeing what your combo makes, sounds like it'll be a pretty stout set up man.
after im done with it the only mods i plan to do is a 90mm tb and a free flowing exhaust 3.5", maybe a cutout too.
Id also like to lose a little bit of weight on the car, it weighs 3200 right now, id like to get down into the 3000's.
the cam i went with should make alot of power throughout the rpms.
specs are LS1-GT2-3 207 / 220 .571" / .578" 118.5
Old 08-24-2010, 12:52 AM
Hey, is there anyway to go to a 90mm tb without buying a complete j tube? do they make a 78mm-90mm adapter?
Old 08-24-2010, 07:47 AM
Klimaxx's Avatar
I have a 70 to 90 mm adapter... but i think it was intended for going from a 78mm TB to a 90MM intake but it would work the other way. Its made out of billet. If your intrested, PM me an offer, I can take pic's if you need
Old 08-24-2010, 07:51 AM
tbird31's Avatar
This is my next setup. Over the next 2 years while finishing school I'll be putting together a LS and slapping a maggie on it...hoping for 600ish.
Old 08-24-2010, 08:53 AM
Klimaxx's Avatar
whats it going in?
Old 08-24-2010, 01:06 PM
Wimimc's Avatar
i was reading that with maggies you dont really need to worry about cam choice like you do with prochargers? is this true?
Old 08-24-2010, 01:27 PM
soundengineer's Avatar
you still need to make a good cam choice to make high boost...but its not as bad as with some other styles of superchargers
Old 08-24-2010, 01:29 PM
so it goes on a 78mm intake so that you can install a 90mm tb on it?
Old 08-24-2010, 02:15 PM
Klimaxx's Avatar
you might need to clearance part of it for the throttle blade to clear, but other than that, yes
Old 08-24-2010, 02:56 PM
I think that's pretty much all the 90mm jtubes are, a 78mm tube with a 90mm adapter welded to it.
Send me some pics please.
Old 08-24-2010, 04:06 PM
Klimaxx's Avatar
Old 08-24-2010, 04:17 PM
  #32
tbird31's Avatar
whats it going in?
my bird
Old 08-24-2010, 06:55 PM
  #33
doom brincer's Avatar
Default here is my maggie
[IMG][/IMG]
MTI clear lid ,Kook 1 7/8 LT header, Kook Y pipe Magnaflow cat back, BMR sub frame connector, trans cooler, 160 thermostat, DMH electric cut out, Comp Cam 230 234 115 lsa .60lb injectors, Magnacharger supercharged with water methanol injection, HP tuner. Tune by Matt at TTP Performance Little Fall NJ 530 RwHP-531 RWTQ.
2001 WS6 Transam convertible
Old 08-24-2010, 07:43 PM
  #34
how much of a difference did the meth do? worth it?
how much does a kit run? how often do you have to put more methonal in? im not really sure on how it works.
Originally Posted by doom brincer
[IMG][/IMG]
Old 08-24-2010, 07:44 PM
  #35
that looks to be the opposite of what im looking for, I need to put a 90mm tb on a 78mm opening, this is for a 78mm tb on a 90mm opening.
where did you find it? maybe someone makes an opposite one.
Old 08-27-2010, 02:38 AM
  #36
farmdawg's Avatar
farmdawg, why did you sell it???
I got a hair up my *** one to own a Corvette, so one morning I got up and had a big bottle of dumbass and decided to trade it in on the 03 Z06. I traded it with everything on it. I really like my Corvette, but I still miss my maggie SS even two years later.
On a side note, I would strongly advise aginst trying to mate a 76mm TB to a 90mm intake, I know it's tuneable and worked on old school 350s when people would put an adapter on the 4bbl intake to mount a 2bbl carb, but on these engines, it's just a choking point. I think you're gonna lose the efficiency that you need to make it work. The Magnacharger is designed to work with the 90mm TB for a reason.
Old 08-27-2010, 10:27 AM
  #37
no title here
skyhighsami's Avatar
Farmdawg how maxed out was your blower at your power level?
Old 08-27-2010, 11:38 PM
  #38
farmdawg's Avatar
It was maxed as far as boost effeciency, anything over 10psi creates too much heat and starts to be too much of a heat soak on the engine to make any power. At my level it was already making tons of heat and traffic wasn't very fun to be in; the temp gauge would get to 230-240 fairly quick and that was with having a 160* thermostat. It was an intercooled system as well. There was a guy on here that was running an MS4 cam with a 3.0 pulley I think and made 574 at the wheels, but his boost was bleeding off from the cam overlap.
Old 09-01-2010, 01:38 PM
  #39
Klimaxx's Avatar
Its funny you say that, the adaptor came straight from magnuson with my supercharger kit.
I can see what caught your eye avout the vette though, my dad has an 03 electron blue as well..
Old 09-01-2010, 07:14 PM
  #40
any idea how much boost a 2.9" pulley will make on an mp112 on an ls1 with stock heads? ls1 is an 02 if that matter.
Quick Reply: Any maggied ls1's out there??
