D1SC set-ups.....how much HP/TQ are you making......
Can you elaborate on this? I know in an na application more overlap will make more power...I can't see why this would not be the same for FI. Some say you will blow boost out with overlap, but a bigger cam should make the same power with less boost, more efficient no?
4L80's are heavy, I bet you make 700RWHP and change with that setup, 750 will be a stretch with a 4L80E but could be done. I'm with NoGo on most of the rest.
[/B]
I was on the stock 4.5" ATI Intercoolers. Meth was my saving grace though, IAT's were consistent 160's, meth kit brought them down to never going over 85* after consistent runs.
I'd like to see some higher compression boost builds, if done right, there is a lot of potential for >9.5:1 CR builds. Lots of manufacturers are starting to go that way. Direct injection and high CR boost builds in LSX cars are what dreams are made of!
[/B]
Overlap uses the exhaust side to scavenge air to the combustion chamber from the intake side, with boost, it's forced in so you do not need overlap. The downside of overlap is it kills vacuum (as both valves are open at the same time).
Trust what trans were you running when you hit the 9.98? 4l80 or 60?
to the op my mods are in my sig. Im pullied for 7lbs but I only see 5 at my high elevation. Im gonna have it re pullied for 10-12lbs. I also recently posted a video of my car at the track in the multimedia section.
1 thing to keep in mind, if you want big power on the 98, you'll need BS3. The 98 PCM is only capable of 2 bar SD, and you can't just plug/play in a 99 harness. Several of the sensors are different, 3 pin opposed to 2 pin etc. Something to consider.
#32
Has anyone ran a D1R? I think the 0 overlap rule on a blower cam is total bs. Non sponsors have gained 80rwhp with a cam that had 40 degrees of overlap over a blower cam. Go do some reading on some of the engine masters blower cam tests from the past. Some of you guys need to start thinking outside of the box, or atleast do some thinking for yourself.
#33
LS1Tech Sponsor
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
I agree that the F-1A is a great way to go. Everything bolts right up as it does with the P and D series. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#34
my #'s are lower than most, but i have run quicker than some claiming over 100 HP more, so what does it really mean, lol
403, Scatt rods/crank, Wiseco pistons, AFR 225 heads, 9.1 comp, EPP cam, 750 blowthru carb, Edelbrock intake, MSD 6010 box, 4L80E trans, intercooler3900 lb Chevelle
with the D1SC intake pulled off, 275 drag radials, best ET was 9.92 @ 135,
11 lbs boost
on the chassis dyno, showed 617 @ 6400, 516 torq @ 6000-the converter didnt like the dyno, stalled a lot higher than in real life
i suspect the cam is somewhat of a mismatch for the heads, 215's would have prob been a better fit, or a custom cam designed for a carb, big heads, but beggers cant be choosie, lol
i run an 8 rib conversion, the AFR's were a little rich, around 1.9, was around 90 degs outside that day-i suspect working on the 60' times (1.60) and cooler weather, i could be down in the 9.8 range, but prob wont fool with it since its just a street car
11 lbs boost
#35
LS1Tech Sponsor
11 lbs boost
11 lbs boost
__________________
#39
I am pretty sure the black car had a 364" LS2 block when it went 8's with the F1A and EPP's camshaft. It didn't run 8's with the D1SC and a 347" LS1/6.
This car ran 9.20's when he had it, and I am anticipating that was in the late fall months or very early spring months with great DA, weather I have yet to race it in. I'll let you know when it is here, I missed the early spring this year. I have put about 25 runs on this car now, all within .1 of one another. It is very consistent for what it is, a solid 9.40 car in the heat without being leaned on. It runs 16* timing and a 11.5:1 AFR and doesn't/hasn't pushed a drop of water on C16 in all of those 1/4 mile runs.
IATs are 150-160 in the summer night heat at the end of a run. In the fall months this will improve substanially and allow more HP to be made.
I also agree on the overlap aspect when chosing a camshaft for these type engines. Centri cars make more HP with bigger camshafts where added overlap is inevitable, don't let that decision hold you back on HP. This car would no doubt run better with a 232/240 115 lsa camshaft over the 224/227 114 lsa cam curently in it. In fact, Kevin made the swap at one point in the 364 LS2 and made a small gain.
