D1SC set-ups.....how much HP/TQ are you making......
Whats your basic set-up:
RWHP?
RWTQ?
Meth...no meth?
Pump gas or race gas?
Cubes? bore x stroke
Compression?
Which Block?
cam specs?
Tranny?
Thanks...I might go this route instead of a big N/A stroker engine.
RWHP?
RWTQ?
Meth...no meth?
Compression?
Which Block?
cam specs?
Tranny?
Buddies 04 M6 GTO I tuned, stock bottom end, trex cam, d1sc. 560 / 500 on 9-10lbs, but just ran 10.7 @ 129 mph, full weight in 4200' density altitude. Car runs like dog **** with no meth, 170-180 degree IAT's but with meth its around 60-70 degrees. Goes from like 12.8 with no meth to 10.7 with lol.
https://ls1tech.com/forums/forced-in...t-results.html
Well thanks for the replies. So...800 RWHP is possible and then some.
So, if I go:
370ci iron block...stock crank & rods
forged pistons
9.8:1 cr
ported AFR 205 heads
ported LS6 intake
93 0ctane
cam...??? Leave that to my builder.
17-19 psi
I should make close to 750 RWHP with a 4L80E?????
How about a 100 shot on top of that? Maybe forged crank and rods if I plan to spray it.
So, if I go:
forged pistons
9.8:1 cr
ported LS6 intake
93 0ctane
17-19 psi
Couple changes:
Go with the 225 heads.
Go with aftermarket rods. They are inexpensive now.
Drop the compression to at least 9.5:1
Select a cam with little or no overlap - some builders know this, some don't.
The D1's that make 800 HP have a nice inlet into the supercharger and a good size intercooler - ditch the ATI setup.
Most will jump right in and say that you should do forged rods right away......
Crank is proven at that power level.
Just a quick thought.......factory rods = free + good ARP bolts = 200 ?
Good forged rod including good bolts = 600 ish
Thats 400 difference.......but motor is already all torn up, so 400 might be cheaper up front.
I say go stock, I want to see these really pushed!
Gluck, have fun
Gluck, have fun
Gluck, have fun
Gluck, have fun
However...... a motor nearly identical to mine (with stock rods) came apart just north of 800 RWHP. The motor was a mess after the failure, but I suspect it was a rod that let go.
You can keep them together with stock rods at that power level, but if the motor hiccups you are going to **** a rod out the bottom of the block.
Also, (IMHO) you should bush the stock rod if you are going to use. After bushing, bolts, and machining you are up to about $400. An aftermarket rod, like you mentioned is $600.
So, if I go:
forged pistons
9.8:1 cr
ported LS6 intake
93 0ctane
17-19 psi
So, if I go:
forged pistons
9.8:1 cr
ported LS6 intake
93 0ctane
17-19 psi
Couple changes:
I was on the stock 4.5" ATI Intercoolers. Meth was my saving grace though, IAT's were consistent 160's, meth kit brought them down to never going over 85* after consistent runs.
I'd like to see some higher compression boost builds, if done right, there is a lot of potential for >9.5:1 CR builds. Lots of manufacturers are starting to go that way. Direct injection and high CR boost builds in LSX cars are what dreams are made of!
I have no problem going forged crank, rods, pistons right off the bat. I'd rather spend it up front then on a tow to a shop and a rebuild. I also want to hit it with spray so better to go forged from the get-go.
"Trust"....
So, regarding a higher compression build, what should I try? I'll be the guinea pig. I also have no problem running full time race gas, but only 103 octane. There's gas stations all over the place down here with 103.
So is 370ci optimal size? Lets put together the perfect build here and I think I'll go for it.
"Trust"....
Why build a 370 when you now have a 427??
Could you have LPE freshen up your existing motor with lower compression pistons? The 427 could support a bigger blower and you could put down some serious power with an F series blower.
LS1Tech Sponsor
Here are two using D-1SC's we did back at the old shop that is no longer in business. Bob
http://www.exoticperformanceplus.com...Car.php?car=42
http://www.exoticperformanceplus.com...Car.php?car=54
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
My 427ci is OLD and tired. Its had a 4.125 stroke in the old original LS1 short sleeves. It needs a rebuild for nobody that wants a powerful N/A only engine.
I want to start fresh with a good iron block.
"Trust"....
"Trust"....
I'd probably stay away from full time race gas if you want to go the gas route, it gets old quick. I had a 101 tune that was 'safe' didn't make anymore power really, but it became a PITA.
I'd build something with a ~4" stroke, good forged internals, pinned mains, thick deck heads, 12 point studs and see what it does. I'm like you to a point, I don't mind being the guinea pig, it's kinda fun. I loved my 396, I just wish my mains would have been pinned so we could have seen what it would really do.
1 thing to keep in mind, if you want big power on the 98, you'll need BS3. The 98 PCM is only capable of 2 bar SD, and you can't just plug/play in a 99 harness. Several of the sensors are different, 3 pin opposed to 2 pin etc. Something to consider.
