Video of dyno run, and dyno sheet! TC78 + 404ci
Nice numbers, that graph looks familiar to mine with the M6. 346", T70, 14psi. It was fun with a 6 speed, but now its a blast with an auto behind it!
http://i18.photobucket.com/albums/b1...0TA/M6dyno.jpg
Small turbine small a/r is making the motor work harder to get the exhaust gas out.
Guys are running T76 w/ 75mm turbines w/.96 housings and having BP issues at 5k on 35x cid and 18psi.
383 T6 1.1 87mm turbine w/80mm compressor are starting to spool at 3k and going 142 at 4400lbs. The extra 2mm on the compressor isn't that much more air compared to your turbo. The extra 2 mm plus the bigger compressor housing and the 19mm bigger turbine is. Will a 78HPS fit your current hotside?
I'd be really curious to see how my 80mm works on your motor. But I can't help test fit it till about January. I have to move and work major OT till mid december. It's 80mmBB w/79mm turbine and divided 1.15 T4.
The latest Engine Masters has the same turbo on a 43x Ford and made 1100 fwhp at 12psi. I'd imagine it has an 87mm turbine at least.
up top.
In fact I just made a 3 1/2 " downpipe from the turbo and now it would easily outspool the .96ar housing with a 3" downpipe, (exhaust is single 3 1/2")
with your cubes I'd be tracking down the biggest ar exhaust housing i could find.
I can only hope to have the same kind of results. Great power, and a great looking car. What turbo do you think would be best fitted to a stock bottom ended 5.3 w/ls6 intake and a mtis1 cam 612/612 244dur 114lsa. Or is this cam to much for a turbo?
