glide vs. th400
Old Sep 7, 2010 | 09:36 PM
camaro383's Avatar
Default glide vs. th400
Wut would be the best option for a strong tranny thats good for street and strip, i have a 3200lb z28 with a 370 and pt88 and 3.73 gears outback
Old Sep 7, 2010 | 10:25 PM
1998TA__1991RS's Avatar
im running a th400 with a 9" 3.70 325/50 drag radial. BW s480, 1.3x 60's off the brake all day long, and able to drive it to the track, im sticking with the th400 mostly b/c its working and i run 90% 1/8th mile
Old Sep 7, 2010 | 10:26 PM
onfire's Avatar
Coal Mining Director
Either built properly will work. ESP with a 2.10 in a 400. Converter will be key.
Old Sep 7, 2010 | 11:50 PM
camaro383's Avatar
I think a th400 comes with a 2.4 first gear, i have a t56 setup now, but i know its gonna be embarassing at the strip, and even on the highway the lag betwwen gears is unacceptable, so im looking for the best priced option that would be best for the street as well as strip.. i would go for the 4l80 but not lookin to drop 4k right now on ranny
Old Sep 8, 2010 | 01:06 AM
Snyper's Avatar
I run a pt88 with a t56 and the lag while very noticable really isnt that bad. And on the highway..with the kind of power it makes..the lag wont really matter..I granny shift my car to wins lol.
Old Sep 8, 2010 | 08:51 AM
slow67's Avatar
Gingervitis Addict
I say th400/4L80E.
Old Sep 8, 2010 | 09:40 AM
camaro383's Avatar
Ya im leaning towards the 400, and the 4l80e is probably a little too much for my pocket..
Old Sep 8, 2010 | 09:44 AM
OUTLAWZ RACING's Avatar
+1 on the 80e just find one in the salavge yard freashin it up and let it eat. A customer car i have bought his for 500 bucks and spent 400 beefing it up just a tad. Goals are 700 to the wheels but the motor let go.
Old Sep 8, 2010 | 09:51 AM
Uglydog56's Avatar
The rule of thumb I have heard is >600hp/<3000# you will et quicker with a glide. If you are considering a 400 I would automatically go for the 4l80e though.
Old Sep 8, 2010 | 10:00 AM
Gordon0652's Avatar
Only time i think of a glide is over 1000hp and then i am still thinking about a th400. Track car only of course.
Old Sep 8, 2010 | 12:45 PM
Snyper's Avatar
What vehicles came stock with the 4l80?
Old Sep 8, 2010 | 01:07 PM
RyanJ's Avatar
SSU Moderator
3/4-ton+ trucks/suvs
Old Sep 8, 2010 | 01:54 PM
droksformula's Avatar
Well imo, you don't need a glide unless your running quicker than 8.5 sec 1/4mile times. The th400 is heavier but you can run a tighter converter and let the lower first gear rip you out of the hole. The the glide is lighter, looks to have more of an aftermarket, but you need more hp to take advantage of the gearing beacause of the high 1st gear and the rpm drop between the 1-2 shift.
Old Sep 8, 2010 | 02:07 PM
98Z28CobraKiller's Avatar
Restricted User
I stockish th400 will handle ALOT more power than a stockish glide. For instance, a $1500 TH400 will handle 1000 rwhp @ 3500-4000#'s . To do that with a Glide you gotta drop way over $2K. The thing is that once you are talking 1500-2000 rwhp, the glide is much easier to build. Just keep throwing billet stuff in there. A good Th400 that will live up there requires more than just good parts as they have more nuances.
Old Sep 8, 2010 | 03:04 PM
camaro383's Avatar
Ya i thoughtb the th400 was a cheaper option at first until now, everywhere i call it is 1900 just for the trans and thats not even with the billet upgraded shafts... plus 1200 for conver,plus 150 for tranny crossmember and the cooler with lines and shifter with cable..
Its adding up to just about 4grand to be all setup, i was thinkin maybe 3grand tops lol
Old Sep 8, 2010 | 03:24 PM
Photochop's Avatar
Powerglide = <3,000 lbs and/or +1000 hp, track only
TH400 = Non highway driven car
4L80E = Best of both worlds (highway/track)
Old Sep 8, 2010 | 03:32 PM
FastKat's Avatar
If that's the case, definitely go with the 4L80E. It should be cheaper than the TH400. The overdrive is going to take away some of the fuel-gauge-pain your 3.73s will give you, too.
Old Sep 8, 2010 | 03:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Well I think it depends on OP's wallet and goals.
I had a TH400 in my '98 Formula and I would do that again over a 4l80e just based on total cost, TH400 would be cheaper.
I'm not a fan of a powerglide for a street car that runs in the 9's or 10's. You don't need it, and who wants to only have two gears for the street and highway. With my 325's, 3.50 gears, and TH400 I could hit the highway though my spool made it a little crazy to wack it.
Old Sep 8, 2010 | 04:24 PM
camaro383's Avatar
Ya im thinkin a th400 for sure, i was curious cause i remember a couple guys said that a pg would make a good tranny for a turbo car...
Im lookin into other options than buyin one, maybe a trade for my 6speed stuff cause it would be cheaper than gathering all the parts separately
But im gonna try the 3.73's i guess and then maybe a gear swap if it doesnt work out
Old Sep 8, 2010 | 04:31 PM
onfire's Avatar
Here's a T400 with a few thousand hp....
http://www.youtube.com/watch?v=Hhfjv...layer_embedded
