what size is the average vaccum line
Old Sep 9, 2010 | 07:03 PM
FasTimeSS's Avatar
Default what size is the average vaccum line
i just ordered twenty feet of this vaccum line and i thought i got the right ****, well no, i get it in the mail today and this **** is as big as moby dick
help
Old Sep 10, 2010 | 05:52 AM
Klimaxx's Avatar
4mm (or 1/8") some are 1/4"
Old Sep 10, 2010 | 09:15 AM
Aster's Avatar
Depends on where the vacuum line is going. The PCV lines are 3/8", lines for gauges and valves are often smaller, as noted above, usually 1/8"
Old Sep 10, 2010 | 04:05 PM
FasTimeSS's Avatar
so 4mm? what mm is 1/4''?
Old Sep 10, 2010 | 04:20 PM
Aster's Avatar
I'm sorry, I went out and checked my car causethe 1/8" seemed small, and my bypass valve and boost gauge connect to 3/16" connections. The 1/4" is used on my coolant crossovers.
Old Sep 10, 2010 | 04:22 PM
Aster's Avatar
Oh and 1/4" is 6.35mm
Old Sep 12, 2010 | 08:20 PM
FasTimeSS's Avatar
so which one would be like on a turbo for a boost port? reason i ask is cus im ordering online and cant tell by the pic.
Old Sep 12, 2010 | 09:34 PM
98Z28CobraKiller's Avatar
Restricted User
1/4" nylon hose by 1/8" mpt quick-fit fittings are what I use. It's clean and easy to connect/disconnect.
Old Sep 12, 2010 | 11:03 PM
Aster's Avatar
Why order it online? Vacuum line is cheap at the local auto parts store. Also measure the fittings the line will be connecting to, if you don't already have them then wait until you do so you'll know for sure you're getting the right stuff.
Old Sep 17, 2010 | 09:59 PM
trans2000am's Avatar
where do you get these from?
thanks
