Building a new kit including headers
Old Feb 28, 2011 | 11:51 PM
  #81
TheLS1Lover's Avatar
Originally Posted by Sluggish
I really doubt it, I work to much to be able to do it. Hell tonight I just started another shut down, 7-12s for the next 40 days. My friend is wanting me to build him a twin turbo kit for his 04 cobra so I may give that a shot next.
If you do this make a thread about it too lol. I would love to see how you cope with a big *** DOHC motor..Lol.
Also I saw that you weren't sure what coating you were going with, ever heard of these guys?
http://www.tiradocustomcoatings.com/
They did my brothers headers and look awesome. Also do a lot of import stuff.
http://www.tiradocustomcoatings.com/ccgallery.html
Old Mar 1, 2011 | 08:09 AM
  #82
Sluggish's Avatar
Thanks for the link, I will give them a call.
Old Mar 22, 2011 | 06:15 PM
  #83
Sluggish's Avatar
Finally finished the turnaround I was on and got back to work on the kit. 50 days strait of working 13-14 hours a day. It was awesome to sleep in this morning, lol.
I built the downpipe today and started on the waste gate. I am going put a v-band on the end of the DP and recirculate the wastegate.
Old Mar 23, 2011 | 03:50 PM
  #84
WS6HUMMER's Avatar
Looking real good man!
Old Mar 23, 2011 | 07:59 PM
  #85
Sluggish's Avatar
Another good day, all I lack on the hot side is the o2 bungs. I going to the hardware store tomorrow and find some stainless nuts that will work.
Old Mar 23, 2011 | 09:08 PM
  #86
prochargedchevyi's Avatar
Great build buddy....Looks like your welds are definitely getting better. Sure appears tha you're getting more comfortable with the 165. Did you ever get the foot pedal?
Old Mar 23, 2011 | 10:23 PM
  #87
Sluggish's Avatar
No foot pedal yet, I have gotten a lot more comfortable with this rig. I think a pedal is going to be a must when I give aluminum another shot. Once you get the base metal when it will take the filler you have to roll the heat way back. I also quit using so much filler rod and just ran the torch down the joint if I had a good fit. Same thing with the slip fits like the v-band. It welded much faster and came out quite a bit better.
Old Mar 24, 2011 | 10:35 AM
  #88
Sluggish's Avatar
T4 T-76 vs the GT88 t6
Old Mar 25, 2011 | 02:44 PM
  #89
WS6HUMMER's Avatar
Yes having a pedal really helps, I tigged all my hot side with a lincoln sa-250 (stick pipeline welder) but with a tig torch scratch starting. Welding without a pedal will make you become a better & faster welder but with aluminum its hard not to key hole it without a pedal. fwiw, just fuse welding does lay out a lot better but if you have a lot of vibration and weight on the welds they are more prone to crack.
Old Mar 25, 2011 | 03:50 PM
  #90
skyhighsami's Avatar
no title here
Are you going to run AC or no? I see it's out now but curious if you'll put it back in. Looks great
Old Mar 25, 2011 | 04:25 PM
  #91
Sluggish's Avatar
No ac, but I think the compressor would fit.
Old Mar 25, 2011 | 06:50 PM
  #92
98TA6.0's Avatar
not with that DP in the way. lol
Old Mar 28, 2011 | 07:54 PM
  #93
Sluggish's Avatar
I was looking at the waste gate and saw that it has water ports, I could rout the steam vents through the gate before going to the radiator, should I?
Old Mar 31, 2011 | 05:49 PM
  #94
Sluggish's Avatar
I got a pile of stuff in so I started moving forward again. I took my intake to have it powder coated and saw that they had a metal fab shop so I got them to bend me a radiator support. I should finish the welding the bungs into the hot side tomorrow and probably take it back to them to have it ceramic coated.
Old Mar 31, 2011 | 05:56 PM
  #95
Josh@KY-Turbo's Avatar
Looks good Pimp.
Old Mar 31, 2011 | 08:05 PM
  #96
JAX04's Avatar
Damn man! That does look killer! Everything looks incredible man! Great work! Def. cant wait to see this one rolling out!
How tall is that intake like that?? do you think you could measure it from valley cover to to the top of the elbow when you get it in their?
Old Mar 31, 2011 | 08:17 PM
  #97
Sluggish's Avatar
Sure can, I will check it tomorrow
I'm thinking of going to a sticker shop, having them put something on the aluminum plate that holds the radiator then bead blast it, any ideas.
Maybe something like this but with Got Boost? with the snail on the side
Old Apr 1, 2011 | 03:44 PM
  #98
Sluggish's Avatar
Probably a little ricer but I think it came out pretty cool.
Old Apr 1, 2011 | 04:04 PM
  #99
TracyRR's Avatar
That is cool! Got boost...
Old Apr 1, 2011 | 07:05 PM
  #100
JAX04's Avatar
That looks absolutely nice! lol
