Building a new kit including headers
Old May 11, 2011 | 08:40 AM
  #121
WS6HUMMER's Avatar
Looking very good!
Old May 18, 2011 | 05:06 PM
  #122
Sluggish's Avatar
The cold side is done and am getting close to having it finished, got the cold side welded today. Maybe I will finish it this week.
Old May 18, 2011 | 10:40 PM
  #123
Sweet_SS's Avatar
Looking good.
Old May 19, 2011 | 07:07 AM
  #124
Denali08's Avatar
That cold pipe is too close to the exhaust collector pipe!
Old May 19, 2011 | 07:27 AM
  #125
TheLS1Lover's Avatar
Yeha I was thinking the same thing, any chance you can put some wrap on there?
Old May 19, 2011 | 08:55 AM
  #126
Sluggish's Avatar
It's over a 1/4" away but I do have some extra wrap just encase, I was thinking of wrapping the pipe all the way to the top of the radiator.
Old May 19, 2011 | 09:45 AM
  #127
WS6HUMMER's Avatar
My charge pipe is about 3/4" away from my down pipe, I wrapped it and didnt have any issues with the charge pipe getting too hot there. I would wrap yours being that close, IMO.
Old May 19, 2011 | 09:54 AM
  #128
robbyredneck's Avatar
mines an 1/4" away and not wrapped and i have not seen an iat over 100*
Old May 19, 2011 | 11:24 AM
  #129
Sluggish's Avatar
That's why I put my sensor down low before the radiator to prevent heat soak.
Old May 19, 2011 | 11:56 AM
  #130
SIC LSX's Avatar
I would wrap all that hot pipe! Hell I would even do the headers. Hint wet the wrap b4 putting it on makes it easy and wraps tighter
Old May 19, 2011 | 11:59 AM
  #131
SIC LSX's Avatar
BTW it looks hard to change plugs. Is it?
Old May 19, 2011 | 12:08 PM
  #132
Sluggish's Avatar
No it's no bad, number 2 is the only slight pain.
Old May 22, 2011 | 07:10 PM
  #133
Sluggish's Avatar
Well I got the car pretty much all back together minus putting the nose on it. Tried to start it but it won't idle and was knocking/ticking. I just pulled the driver side cover to double check the rocker arms and found two that are loose. They are torqued down but have a ton of slack, I'm guessing a few lifters have collapsed. I spun the motor over for a bit to build oil pressure and blow out the cylinders before starting. The car is making 50 psi of oil pressure. I cant remember if they are LS7 or caddy lifters, has anyone had this issue? Last time I drove the car the belt broke and screwed up the front seal, I drove it halfway home stopped put some oil in it then drove the rest of the way (only 5 or 6 miles). Not looking forward to taking this all back apart.
Old May 22, 2011 | 08:14 PM
  #134
MUSTANGBRKR02's Avatar
That is horrible news after all that work.
Old May 22, 2011 | 11:01 PM
  #135
68maroSam's Avatar
This is an awesome build. Great work.
Old May 22, 2011 | 11:38 PM
  #136
kmracer's Avatar
use a vacuum gauge to diagnose it before you tear it town.
Old May 23, 2011 | 12:05 AM
  #137
Sluggish's Avatar
It's definitely 2 lifters on the driver side that aren't pumped up, I will have to check the other side tomorrow. I know people store lifters in oil. My motor hasn't ran or even been turned over in about 9 months. Is it possible to feed the lifter oil from the top through the pushrod hole to help it? I'm not really to positive on how they work.
Old May 23, 2011 | 12:14 AM
  #138
black98ws6ta's Avatar
The lifter should pump up within a few seconds of running with oil pressure. They are fed through the side of the lifter body.
Old May 23, 2011 | 12:36 AM
  #139
kmracer's Avatar
the lifter get oil pressure from the same oil galley that feeds the cam bearings, if you notice there is a small hole in each lifter bore. i doubt the passage is blocked, but its possible. it ran fine when you parked it?
Old May 23, 2011 | 09:09 AM
  #140
Sluggish's Avatar
Yea besides the front seal leaking. I changed the cam also.
I called LME this morning, Brian said it may take awhile to pump back up if it is completely drained.
