ATI ProCharger on 427 10.5:1 compression
Old 02-01-2004 | 02:56 PM
hugger427's Avatar
Question ATI ProCharger on 427 10.5:1 compression
I have a 427 built on a C5-R block platform, running an S1 cam, 6.0 S-3 heads, LS-6 intake, ported TB,etc (currently 503 RWHP/509 RWTQ).. Obviously, the weak link is the top-end compared to what AFR, Fast, and the 90 mm tb's are going to be putting out. However, by the time I buy AFR 225 heads, LSX instake, and 90 mm TB, plus install. I could have the ATI ProCharger (4 psi kit) for the same money and add over 100 RWHP to my current set up...and since I would be pushing air the top end bottle neck is a mute issue...
Also, with 4 psi on 10.5:1 compression what gas will I need to run? Is there anything else I need to consider. This seems like a very safe and cost effective way to push air and eliminating the choked intake issue...please let me know your thoughts.
Thanks,
Ron
http://community.webshots.com/user/rh2772
Old 02-02-2004 | 04:56 PM
BIGBOS's Avatar
You should try and get the comp down to at least 9.5:1, whats the CC on your heads right now?
Old 02-02-2004 | 05:35 PM
niphilli's Avatar
What kind of internals do you have in your 427?
What are the specs on the S1?
This is by no means the ideal setup for FI, but I think it will work just fine if your CR is correct (assuming the heads were milled correctly to get 10.5:1). There are quite a few people running between 4-7# of boost on stock internal LS6 motors. The LS6 is also 10.5:1....The key is to get a good conservate tune with plenty of injector, and dont get greedy with the boost .
Old 02-08-2004 | 02:35 AM
BlackNite383's Avatar
How about a pilots license..lol. That baby will fly with boost added to it. I'm adding 12 to 15#'s to my 383 motor. Big motors with boost sounds fun
Old 02-08-2004 | 08:52 AM
Slowhawk's Avatar
LS1Tech Sponsor
All you need is the tuning done right to run a Blower on 10.5-1..I'm in the process of doing a D1 on a 346 running 11-1 compression and have it run on pump gas..You just need to keep boost at a safe level,timing around 18-22 degree's and plenty of fuel.
Quick Reply: ATI ProCharger on 427 10.5:1 compression
