BEST TRANS for turbo build
Get a 4l80e , they are heavy duty and will hold all the power, they are A4 , so they are good for the street and highway. Its very easy to put it onto your car. As far as your PCM goes, you can use a your current pcm, and whoever is doing your tuning, tell them to do the 4l80e Transmission segment swap onto your tune and do a full flash back into it. If they have EFI Live then its very easy..
Then just get a Yoke, which is like 75 bucks locally. And a flex plate . Then just wire two wires onto the PCM, its easy, just search on the forums or on performancetrucks.net website.
I also have to notch my trans tunnel to make a 4l80 work in my car, new DS, flex plate, and a new shifter, ( i think i read that we cant use our stocker)
stupid GTOs, lol.
thanks for the help on this, sounds like me and the OP are learning alot, lol
personally, im not looking for a hp goal, im looking for solid 9's, based on where im at now it should be obtainable, but well see
getting it to hook can be interesting
that being said, i know my car would be slightly faster and more consistent with an auto than it is now, but the trans hasnt broken and i considered clutches wear items
https://ls1tech.com/forums/forced-in...4l80-swap.html
