LT1 383 Blower Build
I did what I could to support the crank as best I can. Hopefully the callies dragonslayer will be up to the task along with my now custom LT1 big block hub. The blower can't get any closer to the engine so the spacer is necessary and milled accordingly to make sure the blower and crank pulley are aligned perfectly.
Thanks again. Still a lot to get done but hopefully all the little details will make it that much better. More pics to come tomorrow. K-member is going back into the car.
Also big thanks to my friend Jon and my Dad for coming by numerous times to help prep for this day.
Picture time....I can't stop smiling.
Someone hates the new A/C compressor
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Thanks
I sent the trans away today to Tick Performance for their Level 3 build and also asked them to put in new bearings and a viper second gear since I have a pre-2000 trans. Real nice people to deal with so can't wait to get it back.
By the time the trans is back, I hope to have everything else ready to roll besides the exhaust. Idea would be to get the trans in and see if she starts
Looking like a late Feb, early March this will all happen. I will continue to post significant pics when I have them.
Good times...
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Since the last update, the following has happened.
- relocated power terminal/ground terminal
- got most of the EFI connection harness laid out with 90% of the sensors plugged in.
- spark plug wires were made and installed
- put a .10" shim on the blower pulley, everything is lined up absolutely perfectly.
- abs bracket clearanced for the F1A and reinstalled
- mocked up the intake pipe from the engine and found the spot for the open bypass valve (got everything TIG welded and painted black besides the bypass)
- relocated cruise control
- breather installed on passenger side valve cover
- hooked up new clutch slave and mcleod master cyl
- spaced fan motors per prochargers instructions
Lot of other little things have been done as well. Also still a decent laundry list of items that will need to be done.
Got the trans back from Tick on Thursday and put it in after a long Friday night with my buddy Jon. Somehow the nuts for the slave cylinder were misplaced so we were done for the night. Got a lazy start on Saturday since I was up until 2AM the night before. The headers/y-pipe connection really slowed me up. The LPP Y-Pipe fits like **** for lack of a better term. Everything after the Y pipe is going to be fabbed anyway but pretty annoying it didn't slip on like it should.
Anyway, still a lot of little odds and ends to get wrapped up before I can take it for a spin but I think it sounds great.
~65 psi of oil pressure at idle, 60psi of fuel pressure (I know its too high and need to adjust to around 41-43 psi). It started to stumble a touch but then started holding a reasonably steady idle which I assume may be typical of a first start and 80lb high impedance injectors. I was happy to see that Lonnies fuel system worked without any issues. I didn't expect any problems but nice to install something and it simply works!
VIDEO
http://www.youtube.com/watch?v=1yiNsABPaAE
Again, congrats as I know it was a long time in the making!
We has flow?
Old & Busted
New Hotness - Custom Y-Pipe, 4" I-Pipe to 4" single in/out polished SS Magnaflow muffler to hideaway tip
Decided on the flanges over a slip fit for the Y-pipe so if I need to pull the trans or w/e it will be really easy. Everything tucks up nicely for such a large diameter system especially in the crossmember and over the axle area. I had them put two o2 bungs in each 3" section of the Y-pipe and then another after the collector. The tuner may want to monitor each bank and if I upgrade my wideband, I can do the same. The rear sensor I will use for the time being. I'm pretty happy and it sounds pretty nice too.
Here is a video of the car idling (not very exciting) with the new exhaust.
http://www.youtube.com/watch?v=Oh2rZKoo2U0
Well I was able to get the car ready for the dyno tune and headed down to Race Proven Motorsports in Delaware to get the job done. They came very well recommended and it was a solid choice. Fran and his staff were simply top notch. I don't think I've ever felt more comfortable handing my car over to another shop for any kind of work. The lounge was also comfortable and helped keep me relaxed in between dyno pulls.
The results are below and I'm very very pleased with the numbers. I was hoping for anything over 650rwhp and the car did even better. RPM mentioned that it will pick up a bit more with some miles on it but again, I'm very happy with the way everything went. Being the car was not pushed this hard up to this point, a couple minor issues came up but were resolved. As I planned, the driveability is much improved over the old heads/cam setup with the cc306 and spec 3 clutch. The rest is up for me to finish up and get it all set for the open road and eventually the track.
Big thanks to the South Jersey Pals, my close friends, family and the list of supportive vendors listed below.
Race Proven Motorsports - Great shop and very happy with the tune.
Lonnies Performance - Fuel system worked just as intended with zero issues. Excellent customer support and this was probably the only thing that worked right out of the box as advertised.
Bob @ Brutespeed - Great price on the blower setup and very helpful customer service.
Lloyd Elliot Portworks - Very easy to deal with and the parts worked/flowed as advertised. He actually claims the closest guess on the rwhp figure. The setup makes the power with very good driveability. Can't complain with that.
On to the numbers and video.
http://www.youtube.com/watch?v=yM-ECxRfPiU
