Best SC Compression Ratio Street/Strip Car
Ok guys need your opinion I have a forged iron block 408'' bottom end with diamond flat tops and uncut L92 CNC ported heads current CR is right at10.25:1, I want to hang a F1R or a Novi 2000 on the motor should I lower the CR? I have a set of Ross 8.5:1 pistons already I just don't want it to be a dog on the bottom end...oh yeah it is a M6 car with a 9'' 4.10 rear that will see more street miles than track time.
Looking to make some decent numbers north of 750 rwhp
Should I keep the higher CR and run Meth and a air to water or lower the CR and run a FMIC?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
LS1Tech Sponsor
Your compression ratio is not bad at all for a centrifical supercharger. Run methanol injection with it and you'll have a very good combination. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
I personally like about 9.5:1 for a mostly street car. You could most likely get away with either piston you choose. On a careful tune and meth you can definitely still make great power on the 10.25:1 setup.
Since it's going to be mostly a street car, I'd shy away from a air to water and just go with air to air. It will be fine for your goals and much less complex.
Also I would look into running E85, especially if you go with the higher compression.
I was leaning toward the Meth and not having to pull the pistons but I have to wonder how much meth will it drink being street driven at that Hp level or more?
E85 is not an option. I would really like to be able to run it without an IC if I coud get away with it I assume that would take lots of meth and luck...
LS1Tech Sponsor
__________________
