Rings for Boost?
Complete new build and car has made ok power for not being turned all the way up but my question is what are most of you guys using for piston rings where you seeing anywhere from 18-24lbs of boost. When I built the engine the engine builder said the moly top would be ok for the 15-20lb set-up but most guys say to use the steel top for anything over 15. I think im having excessive blow-by and crankcase pressure from my rings already being shot with maybe 650 miles on it and one pass down the track but numerous dyno pulls. Trending Topics
