Forced Induction and #7 Faliure...
A few reasons for the failure that I have heard are:
-Intake manifold design hitting the rear cylinders with more air
-Stock fuel rails starving the rear cylinders
-Using the steam vent block offs on the rear of the cylinder heads instead of the crossover setup
I think I remembered reading that a company with a engine dyno tested the intake manifold theory by turning it around to see if the EGT's on cylinders #7 & #8 changed. I can't remember what the outcome was though....
I would like to hear what you guys think is causing the problem is and what the best remedies are.
I heard that you can just run line to the top of the radiator at the overflow tube but I am not sure on that...
That Evans **** is down right nasty. I mean that in the worst possible way. The cooling system must be completely void of all water/coolant before you put it in. It is EXTREMELY expensive, so be sure that you don't have to drain it for any reason because if you do, you will likely want to catch it. That's when you'll discover how it is impossible to get off anything that it touches. And last but not least, the track guys LOVE cleaning that **** up off the track and I mean that in the most sarcastic way possible. Oh and then there is the psychological impact that it actually raises your coolant temps so you just have to come to terms with the fact that it's better for the engine despite the fact that it reads hotter on the gauge.
i have built a lot of rear coolant cross over tubes. and never had an insue with 7 or 8. i will post some pictures later.
thanks
Besides buying a 01-02 front cross over and putting it in the rear. then y-ing the two together. cost less then 200. and works great on stock stlye intakes.
