Best intake for Forced Induction
Old Dec 27, 2010 | 04:28 PM
PACKETFOCUS's Avatar
How does a Cary intake (which I guess is Mast Motorsports now) work with a turbo setup?
Does the intake play that much of a role in boosted engines vs. NA?
Old Dec 27, 2010 | 04:45 PM
Remo's Avatar
I have a C5 vette with a APS twin turbo kit on it. I was planning on buying the LG turbo upgrade, LPE 100mm MasAir, and a fast 102. After reading im really confused!!
Remo
Old Dec 27, 2010 | 05:08 PM
euroman's Avatar
I run the fast 102. ran all summer street and track 27lbs of boost no problems....at least not with the intake
Old Dec 27, 2010 | 06:16 PM
ajensen383's Avatar
Originally Posted by Shawn @ VA Speed
but the question needs to be asked,what would it run with a different intake and throttle body?
Exactly my point,in all this, alot of guys run pretty fast with all different kinds of intakes, but how do you know what works the best though???
Old Dec 27, 2010 | 06:20 PM
BLNLS1/RX7's Avatar
Wilson Sheetmetal.
Old Dec 27, 2010 | 06:27 PM
Texas_WS6's Avatar
OOOOOOOOOOOO!
I like the look of that Holley High ram!
I think this manifold might be the only manifold I would cut my cowling for.
I wonder if it will fit under a WS6 hood.
Anyone have any ideas what it will cost? I can not wait to see if it is worth the cost and cutting.
Old Dec 27, 2010 | 06:35 PM
JAX04's Avatar
That thing does look nice! id damn near cut a hole in my hood just to let it show
Old Dec 27, 2010 | 06:52 PM
Shawn @ VA Speed's Avatar
Originally Posted by BLNLS1/RX7
Wilson Sheetmetal.
not even close
Old Dec 27, 2010 | 07:02 PM
one of the biggest problems that most people overlook in fi intakes is airflow distribution. While the 4 bbl style intake with an elbow will give you the most hp-it also has the worst distribution. Some of this can be fixxed but not all and it takes alot of work. The pro flow works pretty good but still suffers from distribution problems as well(not nearly as bad as the 4bbl and elbow)
The Holley"looks" like it may be better,but we won't know until we get it on the dyno and get the egt data.
Old Dec 27, 2010 | 07:06 PM
AES Racing's Avatar
Superchiller A2W, won't fit on all LS cars, not saying its best, running air though a core will distribute the air evenly.
It may even fit on a GTO
Old Dec 27, 2010 | 07:18 PM
NicD's Avatar
7 Second Club
What have you seen when comparing the good old LS6 intake to the Pro-Flo? It's probably the only intake out right now that is reasonably priced that makes me half tempted to swap from the LS6.
Old Dec 27, 2010 | 07:47 PM
  #32
tomz28's Avatar
id have to say alot LOL
but what intake for a high hp street car would you go with shawn. id like to know as well.
Old Dec 27, 2010 | 07:49 PM
  #33
flyin's Avatar
Shawn, are the distribution problems of a single blade TB and an elbow on a carb intake cured somewhat by using a carb hat on top of a 4 barrel style throttle body? Or even a 4 hole spacer under that style throttle body?
Old Dec 27, 2010 | 08:42 PM
  #34
Does this have to do with the long side radius moving air faster going into the intake? Ex- the back, or long side of the intake moves air faster then the front or short side radius?
Does air speed come into play because it's boosted into the intake vs. NA?
Old Dec 27, 2010 | 10:25 PM
  #35
ajensen383's Avatar
one of the biggest problems that most people overlook in fi intakes is airflow distribution. .
Very true...We had a little bit of an issue with Andys Pro-Mod intake that we had to "re-engineer" to cut some air out of certain cylinders and direct it to others... Thats why I'm interested in finding what works the best and within my budget...
Old Dec 28, 2010 | 06:05 AM
  #36
stevieturbo's Avatar
Given how long these engines have been about...why are there still so many un-answered questions ?
On the Holley intake, where is the TB ?
Old Dec 28, 2010 | 08:33 AM
  #37
ajensen383's Avatar
Here is a pic of the Holley intake
Old Dec 28, 2010 | 08:47 AM
  #38
Mr.Big's Avatar
Wilson Sheetmetal.
That's my choice Wilson Billet... it is the best imho, but it's not cheap...
Old Dec 28, 2010 | 08:50 AM
  #39
Mr.Big's Avatar
not even close
We have to agree to disagree on this one (for my setup)... I've had the LS2, FAST, and now the Billet... It's a must for me to (on my setup) to retain the stock hood, I can't stand aftermarket hoods...
Old Dec 28, 2010 | 10:17 AM
  #40
The Holley certainly looks nice, and does seem to have quite a large volume. More so than the Edelbrock.
