Fuel sytems?
Old Feb 8, 2004 | 01:10 AM
BlackNite383's Avatar
Default Fuel sytems?
Whats fuel system is everyone running? I'm looking for ideas fir my new setup in my sig.
Thanks,
Den
Old Feb 8, 2004 | 01:20 AM
Jon @ Speed Inc's Avatar
If you have any questions you can email me or tom (jon@ls1speed.com - tom@ls1speed.com) We have developed many of the parts out there and have been testing them to make sure they take the punishment. I will be posting some new fuel rail pictures soon as we are trying different things for the appearance.
Old Feb 8, 2004 | 02:44 AM
BIGBOS's Avatar
I'm running the Speed Inc. fuel rails with a Bosch single 420lph pump with braided lines, current injectors are 42's, if they don't hold up on the dyno then its time for 57#
Old Feb 8, 2004 | 10:08 AM
MIGHTYMOUSE's Avatar
i have two walbro in tank pumps, -6 each into -8 single line up front through speed inc filter, into speed inc rails, out to a cas regulator and back through the stock pressure line. fp rises 1psi per psi and second pump comes on via the boost controller
mototron 60# in the car to see how far they will go, then to probably 83's. w/ the dfi.
pics in sig.
Old Feb 8, 2004 | 01:46 PM
Jammer's Avatar
Speed Inc set up here, same as BigBos but 72lb injectors
Old Feb 8, 2004 | 03:37 PM
NA$TY-TA's Avatar
pics in sig.
MM, I am running what you are running i just havent installed it. What does your see at full boost??
Kyle
Old Feb 9, 2004 | 12:08 PM
Cool...i like the Speed Inc. parts i saw on their site. How does the Bosch 420lph pump mount? Intank or inline?
Old Feb 9, 2004 | 12:30 PM
LS1 SPEED INC.'s Avatar
It can be mounted in-tank, we have never done it that way, we mount it externally.
Tom
Old Feb 9, 2004 | 02:19 PM
smokinHawk's Avatar
I have speed inc fuel rails, dual walbro 340 intankks, feed through a 8an line to a CAS boost reference regulator, returned by the old stock feed line.
42lb injectors for now, but i have some 57's sitting in a box waiting to go in.
detasils of my fuel set up on my web page.(see sig)
Old Feb 9, 2004 | 03:49 PM
S_J_H's Avatar
I'm using an Aeromotive external pump with 10AN feed to it from the stock tank. From the pump 8AN line to Mallory billet fuel rails and Aeromotive regulator with 6AN back to the tank. 42.5lb Flow matched Lucas injectors operating at 62psi WOT. Techedge wideband in car.
Also 15GPH boost powered alcohol system.
Steve
Old Feb 9, 2004 | 11:06 PM
Packy's Avatar
I have a stock intank, inline ATI fuel pump, and 42 lb. injectors! It works for me.
Old Feb 9, 2004 | 11:30 PM
Whistler's Avatar
Sawzall and Welder Mod
I used a factory tank with a sump welded to the bottom, a -12 feed line to a Weldon 2015, -10 to the engine with a Speed INC fuel filter, fuel rails and boost referenced regulator, 75# injectors and a -8 return
Old Feb 11, 2004 | 02:44 PM
I said I'd post them so here ya go
Jon
jon@ls1speed.com
Old Feb 11, 2004 | 03:31 PM
NA$TY-TA's Avatar
Show off...... ha ha lookin good..... I like the colors....... Green???????
