whats your idea of the ultimate street FI motor..
Old 12-30-2010, 09:05 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I just want a modest LSX 427 with 6 bolt heads, a pimp sheetmetal intake, and 899.99RWHP so I can keep my 6 speed and row my own gears- which is how a true street car is supposed to be driven
Jordan_NationalSpeed's Avatar
https://ls1tech.com/forums/forced-in...0-1-200hp.html
Old 12-30-2010, 10:16 AM
Rickys S/C Z28's Avatar
Originally Posted by Shawn @ VA Speed
RHS tall deck 467 cid. Mast MOZEZ heads, Sheetmetal intake, Twin Precision Pro Mod 88mm turbo. Should be good for 1800hp on pump gas.
yelp nail on the head right there.
Originally Posted by 98Z28CobraKiller
That's the direction that I was thinking but it would be stuffed in a 81 Z28 body. Complete modern retrofit suspension and modern interior, pro touring style but it's gotta work. Full stealth exhaust with electric cutouts and a little baby hydraulic cam on E85.
Oh, it would be black on black with black tinted windows and the black Weld Stars. No chrome and no stickers/decals.
im with you on the 81 camaro part(year i was born and my first car.) but it would be black with all the factory stickers(red) and ground effects and a set of CCW 505Aa and a big dick daddy 80 with a trans brake and a 9 in.
Old 12-30-2010, 11:00 AM
Fb0dy0nly's Avatar
ONe that can house the largest properly intercooled twin screw setup under the stock ws6 hood WITHOUT ANY modifications to the suspension or cutting of any stock trim...
Power under the curve baby, power under the curve....
Old 12-30-2010, 02:17 PM
fatmat80's Avatar
Lsx or darton sleeved ls2.. 427 ci
F1R (20#)
Built t56
Fabricated 9 inch
Madman suspension
900+rwhp in more than that and its out of my driving ability..
Old 12-30-2010, 02:35 PM
IMPATIENT 1's Avatar
Originally Posted by tomz28
ok Shawn your killing it for everyone you sick man you need help LOL
and how do you make 2500hp hook on the street? answer is you dont LOL
put a dually rearend with 4 slicks on it j/k
Old 12-30-2010, 04:28 PM
SnIpEz's Avatar
Forged motor, around the 400 ci range, give or take a few cubes. F-1C Procharger, MWC 9", built T56 (I rock the auto and like it but when I think of street driving I think T56). Should easily reach 850, which is my goal. Could always crank it up a tiny bit more I suppose
Old 12-30-2010, 04:47 PM
Detoxx03's Avatar
Forged motor over 400 ci's with a FIA Procharger and of course a built rear and tranny
Old 12-30-2010, 04:50 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
You don't need to. You pass everyone around 150mph, fish tailing, and doing a third gear burnout.
Old 12-30-2010, 06:42 PM
427's Avatar
That sounds fun, but it scares the crap out of you when it happens! After doing that once you may have the same thoughts I did, "I aint trying that again"!
Kurt
Old 12-30-2010, 06:50 PM
xfactor_pitbulls's Avatar
Conventional push rod engines are for pussies. Bell turbine all the way.
Old 12-30-2010, 09:29 PM
  #32
OWN3D BY MY PROF!
Kurt
The reason I mentioned that is I was at one point sitting shotgun as this was happening. I thought afterwards how horrifyingly wrong it could have gone.
Old 12-31-2010, 07:15 AM
  #33
427
427's Avatar
I was driving a Corvette at 41 dragway in Indiana with Michelin Pilot tires and 1400 flywheel HP under the hood. I took off and spun about 4 times at lower speed until I found a throttle position that would not spin but was moving out ok. As I got close to the traps I thought it should take full throttle and I fed it down, it spun hard and upshifted causing the tires to spin for a little after I shut the throttle. The car was just a touch sideways when it stopped spinning, and that threw me back the other way and I almost spun. End result was a dismal 12 second run at 140mph and a new respect for high power on street tires!
Kurt
Old 12-31-2010, 09:16 AM
  #34
N2OBaby's Avatar
Lightbulb
434 LSX block, ported Twisted Wedge 235+ heads, Edelbrock Super Victor Carb intake, 102MM TB, 4.155 bore 9.25:1 CR forged pistons, forged rods,4.0forged crank, "sleeper" Turbo cam, E-85 pump fuel and Meth/H2O injection,Twin MP70 turbos, custom Air-Air intercooler, custom headers, TH400 with Gear Venders under/overdrive, S-60 rear with 4.10 gears & ARB Airlocker, ladder bar rear suspension & mini-tubbs for Hoosier 29X12.5X15 Quick Time Pros or M/T 30X12.5X15 ET Streets.
Build this for a Ford Fairmount Station Wagon!
Old 12-31-2010, 09:36 AM
  #35
Clean94Z's Avatar
Im with RedLs1Z that RCC has the nastiest LSX based FI motor
Old 12-31-2010, 01:07 PM
  #36
I dont think that mine is the ulimate street FI motor but I think it will be extremely fast in my stripped 86 coupe mustang. Looking to make 1000whp@12-14psi
LME LSX 440
Billet main caps
callies dragon slayer crank 4.1 stroke,2.1 rod journals
callies compstar rods 6.125
wiseco 4.125 bore 9:5:1 with poly dyn coating
total seal stainless top ring
napier 2nd ring
3mm oil ring
clevite h bearings
GM ls7x 6 bolt 265cc w/ lme full turbo race port {415 cfm }
2.20 titanuim intake valves
1.615 rev ss exhaust
ls7 rockers with fulcrim upgrade
Cam motion turbo grind cam 242/248 .630 115
jp ls2 dr chain with torrington bearings
morel tie bar high rpm lifters
manley one piece 3/8 pushorods
cometic head gaskets
all arp pro series hardware
moroso sheet metal oil pan with baffle,billet rails and windage tray
melling 10296 pump
Precision Inductions LXR intake
Intake elbows 105mm elbow
Billet 102mm tb
power bond pulley
meizere electric water pump
with twin Precision Billet PT7175's burning threw a T56 magnum
Sounds nasty. But if you are going to all that expense, atleast use inconel exhaust valves.
Old 12-31-2010, 01:12 PM
  #37
Restricted User
98Z28CobraKiller's Avatar
LME LSX 440
Billet main caps
napier 2nd ring
3mm oil ring
clevite h bearings
melling 10296 pump
Billet 102mm tb
power bond pulley
Old 12-31-2010, 01:58 PM
  #38
silver2010's Avatar
UM he said street shawn. Kinda like that 2010 camaro you're building.
Old 12-31-2010, 02:48 PM
  #39
Clean94Z's Avatar
Roll racer! I was gonna do a rossler th400 but cruising at 60-65 would suck. Street car.
Old 12-31-2010, 02:49 PM
  #40
Clean94Z's Avatar
its what they recommended
Quick Reply: whats your idea of the ultimate street FI motor..
