Master power gt45?
I now have it on a stock compression LQ4 6.0L I think its 9.5:1 and on E85 at 15psi.
It spools instantly and definitely makes power past 6k. I never ran it because a noise the engine is making but compared to how it ran on the 5.3 it makes quite a bit of a difference. It was comparable to throwing another 150hp shot at it.
My car went low 10s w/ the 5.3 and didnt spin the slicks after 2nd gear. Now I can blow them off in 3rd gear. I think its sized perfect for a 6.0 or around there and I think its limit is around 800-900whp. MP actually advertises they are good for 1100, but likely fwhp.
the MP 45 uses a fairly large turbine, it will be fine
I use it on a 9.5 370 at 14psi on E85, it made 603/573 to the wheels through a 4L80E and 12 bolt. Went 10.70 at 131 in a 3400lb car with crappy launch. It spools instantly on the street with no traction up to 60 with 315 Nitto DR's.
Next year I plan on switching to a 3 bar tune to really see what the max is. I used a 2 bar thinking that it would be maxed out anyway at 600rwhp. Guess I was wrong. It made max torque at 5200rpm and max hp at 6000 and we shut it off at 6200.
I think its limits are around 700rwhp. We'll see.
I think you will be very happy with it.
http://www.masterpowerusa.com/mp4598.pdf
