Suggestion on possible cylinder head swap
This is the current setup I have:
Should be around 10.5:1 compression
Lunati Pro-mod 6.125 rods
Lunati Pistons/rings 3.903 -2cc
Stock LS1 crank
ARP main studs
ARP headstuds (6point)
Double roller timing set
TREX cam
Westside/LME 5.3 heads 2.02/1.55 valves Rev dual valve Springs
LS6 oil pump ported and shimmed
I want to go forced induction via single front mount turbo. Since this engine is already forged, I was wondering if I can swap out the cylinder heads and lower compression down quite a bit to be safe. I am aiming for 750rwp, I know I will have to change the cam but whats a good turbo cam that is noticeable.
Here are some pics of my current setup..
I have a racetronix fuel pump setup but planning on going dual intank setup.
I sold my fast 92/92 and bought a victor jr with elbow and a ptm 92mm tb.
I like the look of tubular turbo setups so that is the route I am going. Any suggestions would be appreciated.
I am doing alot of researching and I hope to have this done by end of February. The stickies help alot and I still have alot of reading to go.
Stock LS1 crank
ARP main studs
TREX cam
FWIW, I previously had a high compression nitrous setup that consisted of a big cam and 59cc AFR 205 heads. I put on a set of stock 317's and put a Dallas Performance Turbo cam in it and I was good to go.
I did a search and the issues were with the l92 heads not the 317's.
I am now on the look out for ported 317's. I have some LME 5.3 706 heads that are ported if anyone wants to trade? pics are on the first post.
So now, how about a good cam? Something that will get me upto 750rwhp. What about the epp blower cam?
I have a stock set of 317's with the partiot extreme springs if your interested in them. There are a lot of options for cam choices. A budget cam people seem to run and have good results with is a 02-03 Z06 cam. There's quite a few other cams as well. As you said, I've seen a few turbo cars run the Brutespeed blower cam and have good results with a little lope as well.
LS1TECH Sponsor
I have a set of new, never installed, 317 heads fully CNC ported if interested. The have stainless valves, rev springs & titanium retainers. A customer of mine bought them for his car & then decided to build a Warhawk block stroker motor.
Feel free to give me a call.
