Motovative Insta-Boost Quick Spool valve
http://www.streetfire.net/video/new-...ipi_739094.htm
Boost gauge shots in that video from 3000 rpms and 18" vacuum to 15psi.
Drag strip I was leaving at 3300 rpms, 5psi boost on the two step and had 15psi at the 10' mark. My setup lived on that spool valve because of the 2.75 gears and 28" tires, made the car feel super responsive because it was in boost before you could even floor the pedal.
Twin S380's with spool valves on a 408.... geez, that's just scary to think about. I could heads up race anyone at the track an never worry about staging because it took about 1 second to get 5psi on the trans brake/2step setup at 3300 rpm. Just watch the tree and don't worry about anything else.
It is too bad that that business called from Performance Metal Works went belly up... The owner was selling these for the right price.
Now im not going to get into the cost war casue that doesnt acomplish anything other then a flame war that i had to dig through to get to this part of the thread. ridiculous in all honesty.
All of you should know the first new product of any buisness will be marked up higher then most would like. Look at the Xboox 360 when it first came out, $400 plus when it first came out. now you can get a custom one with games, extra controller, head set and free xbox live for a month for that price. look at plasa screens when they first came out. you couldnt find a 36" under $2000. now you can get 55" LCD flat screen for $999 if its sale time.
The point is new products bring new product prices. get over it. on top of it, some one posted exacty what this is. a specailty needs item that isnt on a constant order status. If you can make your own go for it, but dont give the guys a hard time who made it about the price cause you cant afford it. O can afford it at the moment and yes i would LOVE if they brought the price down to $200-250 level, but that isnt gonna happen anytime soon. So bitching about it aint gonna fix it. thats a toddlers mentallity "i cant have it so im gonna whine about it" I deal with that with my 3 year old son enough. Get over it. Lets get backk on topic.
Are there any updates on these spool vales? Aplication changes? power stages? info info info! lol
assunming you buy brand new quality Stainless steel items
flange $100ish
shaft $15-30
plate $20-40
actuator $50-100
tooling $free- 100ish maybe depending on if you have the tools or work at a shop
so as you can see its not that much cheaper to build it yourself and i didnt even mention the time it takes you to make this thing which if your like me, my time is pricless lol
i myself am choosing to buy one later.
I'm gonna street drive a lot and I don't want to be flying at 4k before I start seeing boost pick up...
I have an a4 I want to make this car a bad bitch on the streets
Car put down 500rwp /488rwtq. On 8.5lbs
Ima use same heads and intake on lq9 just not sure about the cam.... Haven't seen a lot of guys run that cam on an s480 on t6 front mount
What ate your thoughts on cam?
