pics of oil return to front timing cover
Old Jan 6, 2011 | 10:46 PM
silversweetZ's Avatar
Default pics of oil return to front timing cover
I did a search and found 2 pictures of people tapping to their front timing cover for oil return. My question is what size of fitting and can you/did you remove the front cover to do this? Any other pictures would be greatly appreciated!
Old Jan 7, 2011 | 09:34 AM
2XR95Z28's Avatar
Also would like to see this, not sure if i'll putting my -10 drain in my timing cover or oil pan. Are you guys able to use a stock crank pulley? i'm using truck pulleys.
Old Jan 7, 2011 | 09:44 AM
yelo04goat's Avatar
x2 in for info
Old Jan 7, 2011 | 11:13 AM
rotary1307cc's Avatar
Here is my -10 I did
Old Jan 7, 2011 | 11:05 PM
Thanks for the photo. I guess the only question I have is will this fit with a stock crank?
Old Jan 7, 2011 | 11:47 PM
mr_biscuitz's Avatar
Does your belt clear the fitting
Old Jan 8, 2011 | 12:57 AM
no1izspeshl's Avatar
I have mine in the same location. Stock crank pulley for an ls1. No issue with the drain and belt
Old Jan 8, 2011 | 08:42 AM
Is this easily removed and installed while still on the car? Or do you have to jack the motor up a bit to get it off?
Old Jan 8, 2011 | 09:07 AM
yelo04goat's Avatar
can some one email me these pics... gov. network wont let me view...
travis.a.wise@cvw2.navy.mil
thanks ahead of time
Old Jan 8, 2011 | 09:24 AM
trans2000am's Avatar
i tapped mine on the other side stock pulley clears with plenty of room, ill try to post a pic
Old Jan 8, 2011 | 11:29 AM
JAX04's Avatar
Here is mine with a stock crank, GTO, not sure if our pulley is different or not.
Old Jan 8, 2011 | 03:01 PM
00bluews6's Avatar
Old Jan 8, 2011 | 08:57 PM
Thanks for posting up the pictures guys. you helped me out big time!
Old Jan 8, 2011 | 10:41 PM
Tally TransAm's Avatar
