Which engine for turbo application, 5.3L or 5.7L LS1?
Old 01-11-2011, 11:38 AM
pwrtrip75's Avatar
Originally Posted by slow67
Go talk to a welder about welding ANYTHING cast....none of them will say its easy....
Cast or forged or whatever process it was formed... if it is a good quality of aluminum it welds fine....Aluminum is aluminum... Lesser grades get more impurities burning out of it when you weld it, depending on what else is in it. but the thicker stuff like heads and blocks people think are poor quality because they are thick. You need to know how to weld thick aluminum. It tranfers heat so fast that a lot of people cant do it. Preheat the **** out of it . The blocks are cast yes but they are not poor quality at all. They weld like butter. The heads are even better. Anything thats had oil on it for awhile you'll need to burn the oil out of it. A couple passes with a TIG to heat and burn it out and then clean each pass good, grind it out, and then once its flowing good and clean you can put a nice fillet in there.
The hear-say that "cast" is harder to weld probably comes from welding cast iron. A lot of people have problems with that as there is a procedure to doing it right. Its not actually harder... its just that you need to know the process.
Old 01-14-2011, 12:20 AM
TXjeepTJ's Avatar
Originally Posted by NemeSS
if it was me. yes.
rebuild the ls1 if thats what you really want. but you can find a complete 5.3 longblock for about that price 400-600$ in running condition.
i have a stock bottom end 4.8 which i plan to push to around 700+rw full trim. and i also have a 5.3 that i will push as much as possible before the 4.8.
the 4.8 has better heads, gaskets, studs.
the 5.3 is completely stock except for upgraded springs and pr
700+ hp on stock bottom end? I've been reading that once you pass the 500HP mark on either engine, it starts to get sketchy. That's why I figured forged pistons/rods would be a must. I'm actually looking to get 500HP to 600HP at the wheels.
what would be your reasoning for choosing 5.3 over 5.7 for a turbo? Besides cost
thanks man!
Regarding my LS1 block, I called a couple professional shops. They both said they would weld up the block, but both also sounded like it wasn't a good idea. That pretty much pushed me away 100% from that option. I would be getting a used LS1 block and transferring parts to that from my LS1. Thing is if I were to get a 5.3, I would need to rebuild it also to add the new pistons/rods and to check everything out. So it comes down to just which would be a better choice for a turbo, which would gain power more easily, reliability, etc.
Old 01-14-2011, 09:34 AM
2nd Gen Fl 'bird's Avatar
Originally Posted by kmracer
AL is super easy to fix. you'd be surprised at how bad of an AL block/head you can just weld up.
and the stock ls1 internals are fine at that power level, so is the compression.
^ what he said
Quick Reply: Which engine for turbo application, 5.3L or 5.7L LS1?
