AES Boost 5.3 shortblock $2599
Old Jan 19, 2011 | 04:07 PM
AES Racing's Avatar
Originally Posted by N2OBaby
Nice shortblock.
How much with ported 5.3L heads?
add.
I have 317 heads,
Hand ported, milled, 5 angle valve job, patriot dual springs, stainless valves.
Comp Cam, cam plate, JP Double Row timing set, LS7 lifters, lifter buckets, GM MLS gaskets, ARP head bolts.
Total comes to $4492, longblock
Old Jan 24, 2011 | 10:03 PM
Slowmo_Bird94's Avatar
Is there any sort of warranty? I know it is iffy when someone else finishes the job, but I am curious.
Old Jan 25, 2011 | 01:10 AM
BottleFedZ346's Avatar
add.
I have 317 heads,
Wow not bad at all!
Old Feb 5, 2011 | 10:00 AM
N2OBaby's Avatar
Question
The more I look at this thread the better it looks.
Are 3.8,3.825,or 3.9 inch forged cranks available?
Old Feb 5, 2011 | 05:50 PM
LS1LT1CAM's Avatar
any more compression possible
might make a great motor for a turbo combo in the lsx real street class
how much off if I supply a l33 crank and block
Old Feb 8, 2011 | 01:41 AM
AES Racing's Avatar
Forged crankshaft is available, however you might as well get a 390 if you want a forged crankshaft my .02
It would be a custom piston to use a larger stroke in 5.3, cost would get out of control.
$2375 if you supply block/crank
price doesn't include any tax
We warranty 90 days on the workmanship and yes you explained it, I don't have control over many variables, basically if you get the motor and say your not happy with something, we can work it out.
Old Feb 8, 2011 | 08:52 AM
N2OBaby's Avatar
Thumbs up
"Forged crankshaft is available, however you might as well get a 390 if you want a forged crankshaft my .02
It would be a custom piston to use a larger stroke in 5.3, cost would get out of control." AES Racing
Thank you for your honest assessment.
Old Feb 8, 2011 | 11:01 AM
projectcam's Avatar
Have you Sonic tested the cylinder walls on the 5.3 iron block and compared it to the 6.0? I was going to have it done a while back just never actually did.
Old Feb 8, 2011 | 01:35 PM
AES Racing's Avatar
Checked 5.3 block at factory bore size I get .215-.220" 360º on the bore (3.780" bore size)
6.0 block I normally see .220" on thrust down to .175" at 3 O'clock on the bore location wise (when bored to 4.030")
Old Feb 8, 2011 | 02:41 PM
projectcam's Avatar
With those numbers the 5.3 block can be punched out to 3.905 without any problems. There is a guy on TurboForums with a turbo Nova that did it and made over 1k to the tires with a 5.3 block/All pro heads and Arp standard sized studs(Bottom end/ Heads). Condsidering people throw those blocks away around here I am suprised more people haven't thrown these together more often. Thanks for the valuable Info!
Old Feb 8, 2011 | 02:55 PM
projectcam's Avatar
http://www.theturboforums.com/smf/in...topic=103675.0
Old Feb 8, 2011 | 05:32 PM
  #32
pwrtrip75's Avatar
If you own a machine shop it might be worth it... but for most people the cost of boring it and stuff you'd be right at the cost of a 6.0 which is bigger. I was just looking into this also. from a 5.3 to a 5.7 it is 21ci ? not worth all the machine work, and if you're going through that much to gain cubes....get a 6.0
Old Feb 8, 2011 | 05:57 PM
  #33
projectcam's Avatar
Thats not why someone would use a 5.3, how many 4inch bore motors you see out there making 1200rwhp without o-rings/1/2 inch studs? There is alot of meat on the deck of the 5.3, that and the fact its iron combined with an aftermarket deck head worked well.
Old Feb 8, 2011 | 07:40 PM
  #34
Ericmck2000's Avatar
What the added price for upgrading to a 6.0?
Old Feb 8, 2011 | 09:19 PM
  #35
AES Racing's Avatar
Starting at $3390
Lot to read in this thread
https://ls1tech.com/forums/forced-in...rankshaft.html
Old Feb 9, 2011 | 12:20 AM
  #36
Starting at $3390
Mmm
2000hp capable
Thanks!
Old Feb 9, 2011 | 05:50 PM
  #37
cjmatt's Avatar
Starting at $3390
what about a plain 6.0 though, not a stroker
Old Feb 9, 2011 | 09:49 PM
  #38
AES Racing's Avatar
370ci $2999 + shipping
CP Pistons -13cc dish
NPR stainless steel top ring set, napier 2nd ring
Eagle H beam rods (arp bolts)
Clevite bearings
6.0 block /crankshaft machined to blueprint and balanced
Old Feb 10, 2011 | 02:50 PM
  #39
cjmatt's Avatar
Clevite bearings
And I can supply my own block & crank?
Old Feb 10, 2011 | 03:39 PM
  #40
N2OBaby's Avatar
Thumbs up
That 3.83 bore 5.3L sounds like an awesome engine to build for FI.
Wonder what it would do with a pair of GT-35's ot Precision TA-5557's?
By Brett Foote | 2026-06-04 05:00:17
