AES Boost 5.3 shortblock $2599
Old Feb 10, 2011 | 03:54 PM
  #41
AES Racing's Avatar
Originally Posted by cjmatt
And I can supply my own block & crank?
Yes, take off $400 if you provide own 6.0 block and crank
Old Feb 10, 2011 | 04:23 PM
  #42
esm's Avatar
esm
Default 5.3
im building 5.3 - boring it to 3.89 using MAHLE pistons and scat rods and stock crank ----im using 2 precision 5557 turbos -- i got the entire 5.3 coils acces and all for $350 and rods and pistons for $715.00 -- bought the pistons used but never used still in plastic and rods new ---im going to pump 15 pounds of boost and hopefully push my stock weight gn into the 9s --- the engine will be in the machine shop next week to get cleaned and bored
Old Feb 10, 2011 | 04:58 PM
  #43
esm's Avatar
esm
Default 5.3
there are plenty of options to make a 5.3 inot a 383 ---- or just a 5.7 ---im using it cause im on a tight budget
Old Feb 10, 2011 | 06:39 PM
  #44
cjmatt's Avatar
Cool Story Bro, prob oughta make your own thread
Old Feb 11, 2011 | 08:44 AM
  #45
esm's Avatar
esm
Default 5.3
sorry i was just trying to add to pros of using 5.3
Old Feb 13, 2011 | 07:27 PM
  #46
slowlsx's Avatar
What kinda compression would you want on a motor like this for 20psi 80mm turbo and 4500lb race weight?
Extra to mill the heads to desired compression?
Old Mar 29, 2011 | 05:39 PM
  #47
flyin's Avatar
bringing this back to life to ask Frasher 2 questions...
is this still a valid price on this shortblock?
and what would the cost be to bore the 5.3L block to a 3.90 bore and do the shortblock that way?
Old Apr 2, 2011 | 06:27 PM
  #48
John510's Avatar
Now I have to decide if i want to order this one or a 6.0. Hmmmm decisions
Old Apr 13, 2011 | 07:54 PM
  #49
Static54's Avatar
Kinda curious about that too. Good summer project.
Old Jan 14, 2012 | 07:51 AM
  #50
WheelsUp84z's Avatar
Back from the dead.. Are you still offering these? With my class limited 76mm non billet wheel turbo, i'd really like the smaller cubes to take advantage.
Old Nov 25, 2012 | 03:49 PM
  #51
FAST LS1's Avatar
Will this short block support 800-900hp or would it need additional options to handle that kind of hp? I wouldn't be worried about a stock crank, but the rod bolts and rods may be a problem?
Old Nov 25, 2012 | 06:48 PM
  #52
I8UR4RD's Avatar
have you read ANY of the threads in the FI section. They are supporting that stock for quite a while, much less forged by a major sponsor!
Go for it!
Old Nov 25, 2012 | 09:06 PM
  #53
FAST LS1's Avatar
I've read many threads, Skinnies, Denmah, etc. but would like to know at what hp AES rates this short block.
Old Nov 26, 2012 | 12:55 AM
  #54
4U2BNVS's Avatar
I think it could support 800-900 but I think you won't get them to rate that high. Too many variables on making it run safely. You need good gaskets a thicker deck head and a good tune. And it all depends on your combination that you add to this.
Old Nov 26, 2012 | 10:28 AM
  #55
TAHOE5.3's Avatar
What's the wait like for 1 of these short blocks and are they still building them? They only have the 390 on their website.
Old Nov 26, 2012 | 10:55 AM
  #56
1CAMWNDR's Avatar
Originally Posted by projectcam
With those numbers the 5.3 block can be punched out to 3.905 without any problems. There is a guy on TurboForums with a turbo Nova that did it and made over 1k to the tires with a 5.3 block/All pro heads and Arp standard sized studs(Bottom end/ Heads). Condsidering people throw those blocks away around here I am suprised more people haven't thrown these together more often. Thanks for the valuable Info!
This 3.83" bore block Fraser is talking about will make you a 333" engine. I don't see 13 cubic inches being worth the loss of some wall strength in a forced induction motor. If you feel like you are missing some power with the smaller motor you can turn up the boost since the thicker cylinder walls will take it!!
Old Nov 26, 2012 | 04:11 PM
  #57
N2OBaby's Avatar
Thumbs up
I agree 100%!!!
Old Nov 27, 2012 | 12:38 AM
  #58
GarrettM's Avatar
Fraser, Im going to have to give you a call soon. I have been set on your 390 for a while for my upcoming build. But now with talk of this 5.3 and the option for a 370 im overloaded with great choices! I will give you a shout for guidance based off of my needs.
Old Nov 27, 2012 | 04:01 AM
  #59
Anchor's Avatar
Fraser doesn't work for them full time anymore. Only some nights every now and then. You're better off talking to one of the other guys.
Old Jan 21, 2017 | 11:42 PM
  #60
B0202033's Avatar
Default Interested
[QUOTE=AES Racing;14379302]I've had many contact me for 5.3 boost shortblock, I listen and here we go.
  • Diamond piston 3.830" bore, -5cc inv. dome dish
  • Total Seal ring set
  • Scat I beam rods, 4340 forged, ARP bolts
  • Factory crankshaft polished and balanced
  • Clevite bearings, durabond cam bearings
  • 5.3 iron block machined and assembled
$2599
Compression ratio using GM MLS gasket
w/ 60cc chamber 10:1
w/ 64cc chamber 9.6:1
w/ 66cc chamber 9.4:1
w/ 68cc chamber 9.2:1
w/ 70cc chamber 9:1
Upgrades,
Scat H beam rods +$100
Total Seal AP top ring +$100
ARP main studs +$188
Aluminum 5.3 block +$200
let me know if you have any questions
Frase
is this shortblock still available? If so how do i order?
