How would you turbo M6 guys like a boost by gear?
Old 06-27-2011, 03:54 PM
  #81
single digit dreamer
parish8's Avatar
i ran a blitz sbc-id color in several cars including my 2009 g8. kinda pricey but it worked great for speed based boost. i ran 8psi up to 30mph, 10psi up to 50mph and 12-13psi from there till the end.
it hooks right up to any older car with a speed sensor. 4 levels of boost. i couldn't find a speed sensor that would work on my g8 so i mounted an old crank sensor on the rear diff near the yolk.
Old 08-11-2011, 05:23 AM
  #82
chucklaw's Avatar
I would love to purchase a unit, but unfortunately I don't have ABS on my car. It's a 88 RX7 with a 5.3L LM7 engine with a 4l60e. I saw that some people are asking if it can be connected to the transmission speed sensor. I'm confused
Will it work this way?
Old 08-21-2011, 04:14 PM
  #83
unnatrl's Avatar
What are the chances of this working on a BMW? The rear diff has a speed sensor that feeds the speedo directly. The car as an LS1/ 6-speed swap, is there a way to hook it to the GM pcm or the transmission speed sensor? Board member Snyper has asked this a few times, but I dont see a clear cut yes or no.
Old 08-21-2011, 07:09 PM
  #84
parish8's Avatar
the blitz unit will hook right up to the gm speed sensor in the tranny. i have done it on a couple of 4l60/4l80e cars. 99% sure the 6speed sensor is the same.
it is likely that the bmw unit it too fine of a signal if it is part of the antilocks but it might work.
Old 10-25-2011, 10:52 AM
  #85
ABeasst's Avatar
Whatever happened with this? I never heard anything back about purchasing one.
Old 10-30-2015, 11:41 AM
  #86
lbm13186's Avatar
Hey guys,
bringing this back from the dead, how does ppl like this after a few years??? is there a better version out there. Please pm me if you're still selling them as I would like to get one.
Old 10-30-2015, 05:28 PM
  #87
Gilberto Barron's Avatar
In for results!!! pm me as well!!
Quick Reply: How would you turbo M6 guys like a boost by gear?
